Force Carrier for Electromagnetism
In summary, the conversation discusses the concept of electromagnetism from a photon force carrier perspective, including the generation of virtual photons around an electron, the polarization of electromagnetism, and the creation of magnetic fields from moving electric fields. The use of Quantum Field Theory and the relationship between classical electromagnetism and Maxwell's Equations is also mentioned. The idea of a dressed electron, which is a superposition of the electron and one or more photons, is also introduced as a key concept in understanding the interaction between electromagnetism and matter.
AustinLee
Can anybody give me or point me to a model that describes how electromagnetism works from a photon force carrier perspective. I like to know how the virtual photons are generated around an electron. Also why electromagnetism is polar. I am also confused why moving electric fields create magnetic fields, and why the magnetic field creates the Lorentz force. The force carrier model seems simple when shown the Feynman diagrams but electromagnetic waves and magnetism confuse me under this model.
you know that's an interesting question and I am not sure physicists know this to the level you're asking.
electrons changing to a lower energy state emit a photon I don't think we can delve into the interaction other than it changes state and a photon of a certain energy is created. Similarly when an electron jumps to a higher state it has absorbed a photon of the exact energy needed to jump. I'm not sure if it can use a photon with a little added energy, absorb it and then spit out a lower energy photon once its made its jump but I don't think its disallowed.
Similarly pulsating EM fields produce radio waves which are photons but how it actually happens is a mystery part of the wave particle duality.
Maybe this will come together once we understand how space is quantized if it is that is.
drakkith that looks right. The last section of the wiki talks about using photons in combination where each would be insufficient.
But I'm thinking the actual creation of a photon is the real mystery may be like asking how an ocean wave is formed the moment its formed.
What do you mean?
i was thinking more of the white crests of the waves as being something that comes into being but really isn't there.
like constructive interference of waves.
AustinLee, It's important to realize that even now, after the advent of Quantum Field Theory, Maxwell's Equations have not yet been repealed! :wink: So the answers to most of your questions simply fall out from classical electromagnetism. The electromagnetic field is still described by a vector potential Aμ, the difference being that it is now an operator. The interaction is JμAμ, total charge is the integral of J0 which may be either positive or negative, and the Lorentz transformation properties of the electromagnetic field Fμν = Aν,μ - Aμ,ν imply that electric fields become magnetic fields and vice versa in a moving frame.
As to the first question, "how the virtual photons are generated around an electron", it's because in the presence of the interaction term, a bare electron is no longer an eigenstate of the Hamiltonian. The corresponding eigenstate of the full Hamiltonian is a dressed electron, namely a superposition of the electron along with a cloud of one or more photons. (This state is time-independent, so there is no 'emitting' or absorbing' going on, it is simply a superposition.)
Related to Force Carrier for Electromagnetism
1. What is a force carrier for electromagnetism?
A force carrier for electromagnetism is a particle that carries the electromagnetic force between charged particles. It is also known as a virtual particle, meaning it cannot be directly observed but its effects can be seen through interactions with other particles.
2. What is the force carrier for electromagnetism called?
The force carrier for electromagnetism is called the photon. It is a massless particle that carries the electromagnetic force between charged particles.
3. How does the force carrier for electromagnetism work?
The force carrier, or photon, works by being exchanged between charged particles. When two charged particles interact, they exchange photons to create a force that attracts or repels them.
4. What is the role of the force carrier in electromagnetism?
The force carrier, or photon, is responsible for mediating the electromagnetic force between charged particles. Without it, there would be no electric or magnetic interactions between particles.
5. Can the force carrier for electromagnetism be detected?
As a virtual particle, the force carrier cannot be directly detected. However, its presence can be indirectly observed through the effects it has on charged particles. Scientists use mathematical models and experiments to study the behavior of the force carrier and its role in electromagnetism.
