Force diagram of a suction cup
In summary: So what the cup does it use suction to obtain a large normal force in order to have a static friction threshold that always matches the force of gravity?
Mr Davis 97
1,462
44
I am a little confused about how to construct a force diagram for a suction cup, like a plunger, as it is stuck to a wall. First, I know that the cup is not accelerating, so the gravitational force pulling down on the cup has to be met with an equal but opposite force vector pointing up. However, why would this vector be pulling up? It is stuck to the side of the wall, so wouldn't the suction force be pointing to the side. This is my question.
... and, can you think of any other force at play?
Normal force?
Mr Davis 97 said:
Normal force?
That's another name for "suction force pointing to the side," the word "normal" meaning "perpendicular to the surface (wall)." What's perpendicular to "normal?"
The only other force seems to be gravity, which acts perpendicular to the normal. But this would mean that the body should accelerate downwards sense there is not counteracting force, and this is why I am confused...
You've overlooked one more force that is at play here. A hint: What would happen if you tried sliding the plunger sideways? What forces would be involved in that case?
Friction? So what the cup does it use suction to obtain a large normal force in order to have a static friction threshold that always matches the force of gravity? (that is, until the pressure inside the suction equalizes)
Related to Force diagram of a suction cup
1. What is a force diagram of a suction cup?
A force diagram of a suction cup is a visual representation of the forces acting on a suction cup. It illustrates the magnitude and direction of the forces involved in keeping the suction cup attached to a surface.
2. What are the forces involved in a suction cup?
The forces involved in a suction cup are the atmospheric pressure, the applied force, and the reaction force from the surface it is attached to. The atmospheric pressure pushes the suction cup against the surface, while the applied force and reaction force balance each other to keep the suction cup in place.
3. How does a suction cup work?
A suction cup works by creating a partial vacuum between the cup and the surface it is attached to. This creates a pressure difference that pushes the cup against the surface, creating a strong bond between the two.
4. What factors affect the strength of a suction cup?
The strength of a suction cup depends on the surface it is attached to, the size and shape of the cup, and the amount of force applied. A smooth, flat surface will create a stronger bond compared to a rough or curved surface. A larger and more flexible cup will also have a stronger hold.
5. Can the force diagram of a suction cup be used to predict its performance?
Yes, the force diagram of a suction cup can be used to predict its performance by analyzing the forces involved and their magnitudes. This can help determine the best suction cup design and placement for optimal performance.
  • Mechanical Engineering
  • Other Physics Topics
12K
  • Classical Physics
  • Classical Physics
