Force due to a magnetic field conceptual question
In summary, a metal loop dropped between the poles of a magnet will experience a force due to the changing magnetic flux, which is opposite to the direction of the increasing flux. This is known as Lenz's Law. The overall force on the loop will be zero due to the cancellation of forces on opposite sides of the loop.
jumbogala
423
A metal loop is dropped between the poles of a magnet. The pole on the left is a North pole, while the pole on the right is a South pole. Assume the magnetic field is uniform between these poles.
Does the loop feel a force? If so, what direction is that force in?
The magnetic field lines point from left to right (eg. North to South). The loop is entering the field, so the magnetic flux through it is increasing towards the right.
To oppose this change in magnetic flux, there is an induced current in the loop that goes in the direction of my fingers when I point my thumb towards the left.
The force felt by the loop, overall, is zero (because on one side of the loop, the force points in one direction. On the opposite side of the loop, the force points in the opposite direction. This means they cancel and the net force is zero).
Can anyone tell me if I'm completely off base here, or if I'm on the right track?
you are correct in your understanding of the situation. The loop will indeed feel a force due to the changing magnetic flux, and the direction of that force will be towards the left (opposite to the direction of the increasing flux). This is known as Lenz's Law - the induced current will create a magnetic field that opposes the change in the original magnetic field. The overall force on the loop will be zero, as you correctly stated, due to the cancellation of forces on opposite sides of the loop. Keep up the good work!
Your explanation is correct. The loop will experience a force due to the magnetic field, known as the Lorentz force. This force will be in the direction of the induced current, which is determined by the right-hand rule you described. However, as you mentioned, the forces on opposite sides of the loop will cancel out, resulting in a net force of zero. This is because the loop is symmetric and the forces on each side are equal and opposite. Good job!
FAQ: Force due to a magnetic field conceptual question
What is the definition of force due to a magnetic field?
The force due to a magnetic field is the force exerted on a charged particle or a current-carrying wire by a magnetic field. It is perpendicular to both the direction of the magnetic field and the direction of motion of the charged particle or current-carrying wire.
How is the force due to a magnetic field calculated?
The force due to a magnetic field can be calculated using the equation F = qvBsinθ, where F is the force, q is the charge of the particle, v is its velocity, B is the strength of the magnetic field, and θ is the angle between the direction of the velocity and the direction of the magnetic field.
What factors affect the magnitude of the force due to a magnetic field?
The magnitude of the force due to a magnetic field depends on the strength of the magnetic field, the charge of the particle, and the velocity of the particle. It also depends on the angle between the direction of the particle's motion and the direction of the magnetic field.
What is the direction of the force due to a magnetic field?
The direction of the force due to a magnetic field is always perpendicular to both the direction of the magnetic field and the direction of motion of the charged particle or current-carrying wire. It follows the right-hand rule, where the thumb points in the direction of the velocity, the fingers point in the direction of the magnetic field, and the palm shows the direction of the force.
How does the force due to a magnetic field affect the motion of a charged particle or current-carrying wire?
The force due to a magnetic field can change the direction of motion of a charged particle or current-carrying wire, but it cannot change its speed. If the particle or wire is moving parallel to the magnetic field, there will be no force. If it is moving perpendicular to the magnetic field, it will experience a maximum force. The force can also cause the particle or wire to move in a circular path.
