Force exerted by a particle in a box on the boundary
In summary, in this conversation, the energy eigen-value of a particle in a box is given by ## E_n = \frac{n^2h^2}{8mL^2}##. By applying classical mechanics, it is determined that ## p \propto \frac{1}{L}## and therefore, the force is proportional to ## \frac{1}{L}##. This leads to the conclusion that the correct option is (b). The concept of force is not commonly used in quantum mechanics, but in this case it is relevant. The eigen energy is the total energy of the particle and not just kinetic or potential energy. The work done on the surrounding is equal to the change in energy, and the force
Pushoam
962
52
The energy eigen - value of a particle in a box is given by ## E_n = \frac { n^2 h^2}{8mL^2} ## .
Now, applying classical mechanics , ## \frac { p^2}{2m} = \frac { n^2 h^2}{8mL^2} ## .
## p \propto \frac { 1} L ## ,
So, the force is proportional to ## \frac { 1} L ##.
So, the answer is option (c).
Can you add some explanation of getting from ## p \propto \frac { 1} L ## to "the force is proportional to ## \frac { 1} L ##"?
Imagine the length of the box is slowly increased by an infinitesimal amount ##\delta L##. By how much does the energy of the system change? How do you account for this change in energy?
## \vec F = \frac { d\vec p }{dt} ##
## p \propto \frac1{ L} ## and L is independent of t. So, ## F \propto \frac1{ L} ## .
But, this approach should not be right as it is classical, should it?
In quantum mechanics, do we talk of force?
The eigen energy is the total energy of the particle, right?
It is not K.E. or P.E. of the particle. Right? ## dE = \frac { C} L dL ##
## \frac { dE} {dL } = \frac { C} L ##
Where C is an appropriate constant.
Is ## F = \frac { dE} {dL } ## ?
Then, isn't this energy only potential energy instead of total energy?
I think you can get the answer with a hybrid classical/quantum argument where you use a kinetic-theory-of-gases approach to relate the force to the momentum. But, it would be better to get the answer without using the classical "hand waving".
Not often in my experience. But here we are. :oldsmile:
Right.
I don't follow this. Use your expression for En given in the first post.
Yes.
No, you want E to be the total energy. The idea is that the loss of total energy of the system (as it expands) equals the work done by the system on the environment.
## dE = \frac { C} {L^3} dL ##
## \frac { dE} {dL } = \frac { C} {L^3} ##
dE is the work done on the surrounding
dE = F. dl
So, F = ## \frac { dE}{dl} ## .
So, the correct option is (b).
To take a completely classical approach, for gaseous particles, ## PV=nRT ##, and in this case we are considering the pressure or force in one direction. For a single particle at a given energy, the force should indeed be inversely proportional to the length of the box. That is a result of the number of collisions with the wall is inversely proportional to the length. Any QM result should agree with this. When considering the Q.M. wave in momentum space, it the particle doesn't have a precise location, but simply has an average momentum at the wall that causes a force there. I agree with the OP's original answer.
dE = F. dl
Looks good to me.
Likes Charles Link
But the force depends on more than just the rate of collisions.
My expertise at Q.M. is rather limited. I'm going to need to study this further. :)
According to the Bhor's Correspondence principle, for large n, quantum results tend towards the classical results.
So, for large n,
I got this idea right now. So, I posted it to get it checked.
You get a minus sign when you take ## dE/dL ##. You need to go to a higher quantum number ## n ## to keep the particle at the same energy as you expand the box. The energy isn't staying the same at a given ## n ## when you expand the box, and any energy you input is not getting expended as work done to the surroundings. I think any results that are obtained by interpreting ## dE/dL ## are incorrect here, but again, this is outside of my area of expertise, and I will need to study it further.
Charles Link said:
You get a minus sign when you take dE/dL . You need to go to a higher quantum number n to keep the particle at the same energy as you expand the box.
The particle will not be at the same energy as I expand the wall. Its energy will decrease. The decrease in energy is workdone by the particle on the boundary walls.
Why do I need to go to a higher quantum no. n for this purpose?
No energy is being given to the particle from outside agent. The particle loses its own energy by increasing walls separation.
Your post 5 gets you a different answer. That's why I'm giving this one further study. I'm inclined to believe your first answer (c), but at present, I'm not completely satisfied. ## \\ ## Editing: A google of this seems to show that ##1/L^3 ## is the correct answer, so that I'm going to need to try to digest it in detail. And the answer seems to be, you need to push on it to compress it, when it stays in the same quantum state ## n ##, and its energy increases. Thereby, the force is proportional to ## 1/L^3 ##. Thank you @TSny . These Q.M. problems can be quite educational. :)
So, for large n,
Yes, ## p \propto \frac { 1} L ##. (You can also get that from de Broglie's ## p = h/\lambda## and the fact that ##\lambda =2L## for the ground state.)
But how does this imply that the force is proportional to ## \frac { 1} L ##?
For a classical particle bouncing back and forth in the box, the average force is the change in momentum per collision times the number of collisions per unit time.
The change in momentum per collision is 2p. The rate of collisions at one end of the box is v/(2L) = p/(2mL).
So, classically, F = 2p⋅p/(2mL) = p2/(mL).
Using the de Broglie relation p = h/λ = h/(2L), you get F = h2/(4mL3).
This hand waving argument happens to give the same result as dE/dL.
Likes Pushoam
TSny said:
But how does this imply that the force is proportional to ## \frac { 1} L ## ?
F = ## \frac {dp }{dt} ##
Since L is independent of t, it is size of box, I thought of taking ## \frac 1 L ## out of differentiation and I didn't think of other factors (thinking that the question asks only for L - dependence of force).
This wrong attitude towards other factors led to the wrong answer.
Why do you call it a hand waving attitude?
It's called a "handwaving" approach or argument. I think the phrase comes from when a magician waves his hands over the hat, and makes the rabbit disappear, etc. I use the phrase quite commonly also. It generally applies when the mathematics is not completely rigorous.
Likes Pushoam
FAQ: Force exerted by a particle in a box on the boundary
1. What is the definition of "force exerted by a particle in a box on the boundary"?
The force exerted by a particle in a box on the boundary refers to the amount of force that a particle inside a confined space, such as a box, exerts on the walls or boundaries of that space.
2. How is the force exerted by a particle in a box on the boundary calculated?
The force exerted by a particle in a box on the boundary can be calculated using the formula: F = -dp/dx, where F is the force, p is the momentum of the particle, and x is the position of the particle.
3. What is the significance of studying the force exerted by a particle in a box on the boundary?
Studying the force exerted by a particle in a box on the boundary can help us understand the behavior of particles in confined spaces and how they interact with their surroundings. This knowledge can also have applications in various fields such as materials science, nanotechnology, and quantum mechanics.
4. How does the force exerted by a particle in a box on the boundary change with different boundary conditions?
The force exerted by a particle in a box on the boundary can vary depending on the type of boundary conditions, such as fixed or periodic boundaries. For example, in a fixed boundary, the force may increase as the particle approaches the boundary, while in a periodic boundary, the force may oscillate as the particle moves within the box.
5. Can the force exerted by a particle in a box on the boundary be negative?
Yes, the force exerted by a particle in a box on the boundary can be negative. This occurs when the particle's momentum is decreasing, causing the force to act in the opposite direction of its motion. Negative force values can also be seen in quantum systems due to the wave-like nature of particles.
