I Force exerted by an iron core electromagnet on a ferrofluid
The discussion centers on the inadequacy of the standard equation for calculating the force exerted by an electromagnet, which does not account for the material being attracted or the core material's properties. The equation presented, F=((NI)^2 A mu0)/2X^2, is critiqued for providing a flat force value, ignoring the significant differences in magnetic attraction between materials like iron and ferrofluid. The impact of core material, particularly its permeability, is highlighted, with pure iron having a relative permeability of around 5000, though practical applications may vary. The complexity of the problem is acknowledged, suggesting that a complete calculation formula may be challenging to derive. Understanding the physics of electromagnets is recommended for a more thorough grasp of these interactions.
EmeraldPlatypus
I am trying more generally to find the equation of the fore exerted by an electromagnet. The one that I keep finding is
F=((NI)^2 A mu0)/2X^2.
N is turn number, I is current, Mu0 is permeability of free space, A is the area of the core and X is the distance from the electromagnet.
I take issue with for a number of reasons. Firstly, surely it depends on the material I am trying to attract. I know from experience that a magnet that can lift a few hundred gram of iron can barely lift a gram of ferrofluid, and the equation just gives a flat force.
It also doesn't account for any core material. As far back as GCSE I have been told that "an iron core makes the electromagnet stronger" Well how much stronger? And to what property of the material does this strength increase correlate??
Can anyone give me an equation that shows some dependence on core material and the material that will be attracted to the electromagnet, as well as all the stuff listed in the (as I see it) in complete EM force equation
You hold a short, thin rt. circular cylinder , length l, made of hi-mu metal, e.g. iron, coaxially and near a solenoid (not inside). The axial B field will be stronger near the solenoid & weaker as you move away axially.
There will be a force applied to the near end surface of the cylinder "sucking" it towards the solenoid, and a lesser force sucking it away from the solenoid on the far end. If the cylinder has very high permeability the net pressure on the cylinder will approximate ## Bl \nabla B/\mu_0 ## since each side sees suction pressure ## B^2/2\mu_0 ## with B the respective value at each cylinder end.
If the cylinder has zero relative permeability then there is no force. If its permeability is finite but not arbitrarily high then there is a force on the cylinder but the computation becomes difficult.
Because the relative magnetic permeability of pure iron is around 5000, it is ideally 5000 times under certain conditions. However, in most practical situations, it is believed that this maximum value will not apply.
https://en.wikipedia.org/wiki/Permeability_(electromagnetism)
This is closer to an engineering problem than a physics problem, and is a more complex case involving multiple parameters. It may be difficult to give a complete calculation formula. Maybe you should study the physics of electromagnets first. This should help you understand the problem thoroughly.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
