Force exerted on a pivot point
In summary, the problem involves a 4.0 m long horizontal plank with a mass of 24.0 kg resting on two pivot points. The question is asking for the magnitude of the force exerted by the second pivot point, which is located 1.0 m from the right end. To solve this, one must draw a diagram, take moments about a convenient point, and use the fact that the plank is in translational and rotational equilibrium. By setting the sum of the forces at the pivot equal to the weight of the plank and considering the equal and opposite torques exerted by each pivot, one can solve for the magnitude of the force exerted by the second pivot point.
benshields
A horizontal plank 4.0 m long and having mass 24.0 kg rests on two pivot points, one left at the end and a second one 1.0 m from the right end. What is the magnitude of the force exerted on the plank by the second pivot point?
I'm not even sure how to attempt this problem
Draw a large diagram and mark on the forces and their location.
Take moments about a convenient point.
Draw a free body diagram.
Assuming the mass distribution is same, take the centre of mass at the centre i.e at 2.0 metre.
The plank is in translational and rotational equilbrium.
Thus, the sum of magnitude of the forces at the pivot is equal to the wieght of the plank.
And, the moments, or the torque exerted by each of the pivot is equal and opposite thus their magnitudes are equal.
Take the origin as the centre of mass.
PS:- Torque= Force*distance of action from the origin (when force is perpendicular)
In vector notation torque is the cross product of radius and force. But the above equation is enough here
Hope it helps :)
Related to Force exerted on a pivot point
What is a pivot point?
A pivot point is a fixed point or axis around which an object can rotate or move.
What is the force exerted on a pivot point?
The force exerted on a pivot point is the amount of energy or effort applied to a pivot point in order to cause movement or rotation.
How is the force exerted on a pivot point calculated?
The force exerted on a pivot point can be calculated using the formula F = r x F, where F is the force applied, and r is the distance from the applied force to the pivot point.
What factors affect the force exerted on a pivot point?
The force exerted on a pivot point is affected by the magnitude and direction of the applied force, as well as the distance between the applied force and the pivot point.
What are some real-world examples of force exerted on a pivot point?
Some examples of force exerted on a pivot point include the movement of a seesaw, the rotation of a door on its hinges, and the turning of a steering wheel in a car.
