Force from two point charges on a third one
In summary, given three point charges forming an isosceles triangle, with two sides of equal length, located at specific coordinates, the resulting force on the third charge can be calculated using the superposition principle and Coulomb's law. For the cases where Q2 is equal to Q1 and where Q2 is equal to -Q1, the resulting force can be expressed as vectors along the center line of the triangle and parallel to the line connecting the two other charges, respectively.
silverwhale
84
We have three point charges [itex] Q_1, Q_2, Q_3 [/itex], forming together an isosceles triangle. Two sides are of equal length [itex] r [/itex].
The point charge [itex]Q_1[/itex] is located at [itex] (0,0)[/itex],
the point charge [itex]Q_2[/itex] is located at [itex] (x_2,0)[/itex]
and The point charge [itex]Q_3[/itex] is located at [itex] (\frac{x_2}{2},\sqrt{r^2 - ({\frac{x_2}{2}})^2})[/itex].
Calculate the resulting force on [itex]Q_3[/itex] for the cases [itex] Q_2 = Q_1 [/itex] and [itex] Q_2 = - Q_1. [/itex]
I think two formulas are relevant. Coulombs law and the superposition principle.
From the Superposition principle and Coulombs law we have:
[tex] \vec{F}_3 = \frac{1}{4 \pi \epsilon_0} Q_3 Q_1 \frac{\vec{x}_3 - \vec{x}_1}{|\vec{x}_3 - \vec{x}_1|^3} + \frac{1}{4 \pi \epsilon_0} Q_3 Q_2 \frac{\vec{x}_3 - \vec{x}_2}{|\vec{x}_3 - \vec{x}_2|^3},[/tex]
where [itex]\vec{F}_3[/itex] is the resulting force on [itex]Q_3[/itex].
Next, I calculated [itex] \vec{x}_3 - \vec{x}_1 = (\frac{x_2}{2},\sqrt{r^2 - ({\frac{x_2}{2}})^2}) [/itex]
and [itex] \vec{x}_3 - \vec{x}_2 = (-(\frac{x_2}{2}),\sqrt{r^2 - ({\frac{x_2}{2}})^2}). [/itex]
Then I calculated the norm of both to get [tex] |\vec{x}_3 - \vec{x}_1| = |\vec{x}_3 - \vec{x}_2| = r. [/tex]
So I get for [itex] \vec{F}_3 [/itex],
[tex] \vec{F}_3 = \frac{1}{4 \pi \epsilon_0} \frac{Q_3 Q_1}{r^3} (\frac{x_2}{2},\sqrt{r^2 - ({\frac{x_2}{2}})^2}) + \frac{1}{4 \pi \epsilon_0} \frac{Q_3 Q_2}{r^3} (-\frac{x_2}{2},\sqrt{r^2 - ({\frac{x_2}{2}})^2})[/tex]
Now for [itex] Q_2 = Q_1 [/itex]:
[tex] \vec{F}_3 = \frac{1}{4 \pi \epsilon_0} \frac{Q_3 Q_1}{r^3}( (\frac{x_2}{2},\sqrt{r^2 - ({\frac{x_2}{2}})^2}) + (-\frac{x_2}{2},\sqrt{r^2 - ({\frac{x_2}{2}})^2}))[/tex]
thus,
[tex] \vec{F}_3 = \frac{1}{4 \pi \epsilon_0} \frac{Q_3 Q_1}{r^3}( 0,2 \sqrt{r^2 - ({\frac{x_2}{2}})^2}).[/tex]
And for the case [itex] Q_2 = - Q_1 [/itex]:
[tex] \vec{F}_3 = \frac{1}{4 \pi \epsilon_0} \frac{Q_3 Q_1}{r^3} (x_2,0).[/tex]
Is this correct? What do you think?
Can you edit your post and remove all the extra blank homework template stuff?
It will be easier on the eyes.
Ok! Done!
it looks right. Have you plugged some numbers in and sketched the vectors on paper to see if the result looks reasonable?
When the two charges are the same then the third charge will either move away or be attracted to the other two. In either case, the force will be along the center line through the isoseles triangle.
When the two charges are different then the third charge will move on a line going thru the third charge and parallel to the line going thru the two other charges initially. The resultant force should be parallel to these lines.
Thanks jedishrfu! I'll plug in some numbers and draw the vector to reproduce your argument!
Thanks again!
Related to Force from two point charges on a third one
1. What is the formula for calculating the force between two point charges on a third one?
The formula for calculating the force between two point charges on a third one is given by Coulomb's Law, which states that the force is directly proportional to the product of the two charges and inversely proportional to the square of the distance between them.
2. How can the direction of the force be determined?
The direction of the force can be determined by using the principle of superposition. This means that the individual forces from each pair of charges can be added together vectorially to determine the overall direction of the force on the third charge.
3. What happens to the force if the distance between the two charges is doubled?
If the distance between the two charges is doubled, the force will decrease by a factor of four. This is because the force is inversely proportional to the square of the distance, meaning that as the distance increases, the force decreases exponentially.
4. How does the force change if the magnitude of one of the charges is increased?
If the magnitude of one of the charges is increased, the force between the two charges will also increase. This is because the force is directly proportional to the product of the two charges, meaning that as one charge increases, the force increases proportionally.
5. Can the force between two point charges on a third one ever be zero?
Yes, the force between two point charges on a third one can be zero if the two charges are equal in magnitude and opposite in sign. In this case, the forces from each pair of charges will cancel each other out, resulting in a net force of zero on the third charge.
