Force of declerating object losing mass
In summary, a spacecraft with a mass of 10,100 kg, including fuel, is traveling at a speed of 6 m/s in free space. After firing its rocket engine for 4 seconds and ejecting 100 kg of fuel, the spacecraft's speed decreases to 0.02 m/s. To calculate the force, we can use the equation F=ma and take into account the average mass of the spacecraft before and after the fuel ejection. The concept of conservation of momentum does not apply in this scenario.
Lukec29
A spacecraft traveling in free space, at a speed of 6 m s -1 has a mass of 10,100kg (including fuel)
A rocket engine on the spacecraft is fired up for 4 seconds, ejecting 100kg of fuel and slowing the spacecraft down to 0.02 m s -1
What is the force in Newtons, feing the 4 second burn of the spacecraft .
I really new to physics, and this is an example question in order to help us understand how to work these type
Of equations out.
I know that f = m a, however in this case I think the fact that the spacecraft is losing weight needs to be taken into acount.
The momentum before is 60,600 kg -1 s -1
As I said before I am really new to physics and being able to understand the reasoning for the formula is my main aim here.
Thank you in advance to any help that may be given here.
Hi Lukec29. http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
It's probably good enough to use the average of its mass during that time in your calculations.
Do you know what the expected answer is?
Unfortunately not, my tutor is on holiday currently. I am more looking for the correct workings so I can understand the formula and put it to practice.
As long as the mass is decreasing "linearly", at a constant rate, then you can use the average mass as if it were the mass the entire time.
Initially, the mass, including fuel is 10,100 kg. At the end of the 4 seconds firing, the mass is 100kg less (I am assuming you did NOT mean "100 kg per second") so the average mass, over the 4 seconds is [10,100+ (10,100- 100)]/2 kg. Use that with "F= ma".
What do you know about conservation of momentum?
Nothing at all, it's degree level but first year, very simple.
Would force in Newtons, from the average mass of before and after ejecting the fuel suffice
FAQ: Force of declerating object losing mass
What is the force of a decelerating object?
The force of a decelerating object is the amount of resistance or pushback that is acting against the object's motion. It is the result of the object's mass and its acceleration.
How does a decelerating object lose mass?
A decelerating object can lose mass through a process called mass transfer. This occurs when a portion of the object's mass is transferred to another object through contact or interaction.
What factors affect the force of a decelerating object?
The main factors that affect the force of a decelerating object are its mass, acceleration, and the opposing force or resistance acting against it. Other factors such as friction, air resistance, and surface conditions can also play a role.
Can a decelerating object lose mass without an external force?
No, a decelerating object cannot lose mass without an external force acting upon it. This is because the object's mass is a constant and cannot change on its own. Any change in mass would require an external force to cause a transfer of mass.
How does the force of a decelerating object change over time?
The force of a decelerating object decreases over time as the object's speed decreases. This is due to the decrease in acceleration, which is the rate of change of velocity. As the object slows down, the force acting against it also decreases until it reaches a state of equilibrium or comes to a complete stop.
