Force of Earth's gravity on a spacecraft
In summary, the force of Earth's gravity on a spacecraft 8016 miles above the Earth's surface would be 9.8 Newtons.
fattydq
79
Calculate the force (in Newtons) of Earth's gravity on a spacecraft 12900 km ABOVE the Earth's surface if its mass is 1410 kg.Give 3 sig figs.Be careful with your units!
Again, here I know force is mass times acceleration, so would it just be 1410 times 9.8? The thing that worries me is this seems way too simple for the type of problems we've been doing, haha, I feel like I'm missing something?
And where does the fact that it's 12900 km above Earth's surface come into play here??
No. That would be wrong.
Hint: Newton's law of gravitation.
Hmm I know the basics behind that law but don't see how I can numerically use that principal to solve this?
I honestly thought that law came into effect in the form of an equation when you're working with two different masses and whatnot...how would I apply it in this situation?
Unless...does the mass of the entire Earth come into play here? That wouldn't really make much sense, because that isn't really known is it? Again what are the two unique masses I'm supposed to use here?
Correct.
Where did you ever get this idea?
Fg = G(m1)(m2)/d2
G = 6.67x10-11
m1 = mass of ship
m2 = mass of earth
d = distance (note: squared)
Then what is the known mass of the earth? Because I just searched it and got 4 different (similar) answers...
5.9742 × 10^24 seems to be the most popular, yes?
I got 3380000000 and my units would be Newtons, is this correct?
Monocerotis,
1. Please don't give too much help here. Our job is to help students do their own homework, not do it for them.
2. G=6.67x10-11 what? What units, to be specific.
G is not a unitless constant. Solar system dynamists are just as likely to use G=1.4879×10-34 AU3/day^2/kg as they are to use G=6.674×10-11 m3/s2/kg.
Two problems here.
1. Units.
2. The distance is to the center of the Earth, not the Earth's surface.
D H said:
Monocerotis,
So my final units wouldn't be Newtons? I know the G constant is in m^3 kg^-1 s^-2 but since it asks for the final answer in Newtons I'm assuming that's what the end product will be?
D H said:
Two problems here.
1. Units.
Well how the heck am I supposed to know the distance to the center of the Earth when it would surely vary at different poles/locations on earth?
And how can the units be converted to Newtons if what I figured out isn't in Newtons? Because the original problem says calculate the force in Newtons...
Ignoring the 21 km difference between the equatorial and polar radius is a heck of a lot better than ignoring the radius of the Earth altogether.
What are the units for G? Is this compatible with the other units you are using?
D H said:
Ignoring the 21 km difference between the equatorial and polar radius is a heck of a lot better than ignoring the radius of the Earth altogether.What are the units for G? Is this compatible with the other units you are using?
The units for force is Newtons normally, and gravity is a force that's being calculated here, I still don't see what you're getting at. I appreciate the help, I hope I don't sound ungrateful, it just seems you're answering my questions with more complex questions that I can't answer.
You used G=6.67x10-11. What are the units associated with that number?
Suppose you had been told the satellite was 8016 miles above the surface of the Earth instead of 12900 km. How would you have solved the problem given this information?
FAQ: Force of Earth's gravity on a spacecraft
What is the force of Earth's gravity on a spacecraft?
The force of Earth's gravity on a spacecraft is known as the gravitational force and is measured in units of Newtons (N). The magnitude of this force depends on the mass of the spacecraft and the distance from the center of the Earth.
How does the force of Earth's gravity affect a spacecraft?
The force of Earth's gravity can affect a spacecraft in multiple ways. It can pull the spacecraft towards the Earth, causing it to accelerate and change its trajectory. It can also cause the spacecraft to experience weightlessness when in orbit, as it is constantly falling towards the Earth but moving fast enough to stay in orbit.
How is the force of Earth's gravity calculated on a spacecraft?
The force of Earth's gravity on a spacecraft is calculated using Newton's Law of Universal Gravitation, which states that the force between two objects is directly proportional to the product of their masses and inversely proportional to the square of the distance between them. This formula can be used to calculate the force of gravity between the Earth and the spacecraft.
Can the force of Earth's gravity be changed on a spacecraft?
The force of Earth's gravity cannot be changed on a spacecraft. However, the effects of this force can be counteracted by other forces, such as the thrust of a rocket engine. This is how spacecraft are able to break free from Earth's gravity and travel to other planets and moons.
How does the force of Earth's gravity differ on different spacecraft?
The force of Earth's gravity is the same for all objects, regardless of their mass. However, the effects of this force may be different on different spacecraft depending on their mass and distance from the Earth. For example, a larger and heavier spacecraft will experience a greater gravitational force compared to a smaller and lighter spacecraft at the same distance from the Earth.
