Force of Falling Objects at a Height
In summary, the conversation discusses the factors that contribute to the force of a falling object dropped from a height and the calculation of the restoring force of a spring after impact. The solution presented involves the use of conservation of energy, but is questioned by some participants. It is suggested to consider the energy stored in a spring and the momentum of the object to fully understand the problem.
Samei
33
: [/B]I'm curious to know why and how one would account for the force of a falling object dropped from a height. If I apply Newton's 2nd Law, force is only dependent on acceleration. So in a straight vertical drop, this acceleration is only gravity. But is it not that a bowling ball dropped from a skyscraper will have more force crashing down into the ground than the same ball dropped from only half a meter of a height?
Here is my problem: If I drop a ball into a spring from a given distance x, the spring will compress. Assume that the ball sticks to the spring. After impact, the spring will eventually have a restoring force to counteract that force. But how much is that force? It is not equal to the weight of the ball, is it? (In this case, the spring is massless. Only mass of the ball (m), spring constant (k), and distance of the ball from spring (x) is given.)
: [/B]F = m * a, F (spring) = -kx, W = KE2 - KE1, Conservation of Energy, W = Fd
: [/B]W = KE2 - KE1
KE2 = mgx by conservation of energy, x is the height
KE1 = 0, because ball is being dropped
W = KE2 = mgx
and F = W/d
Substituting,
F = (mgx)/d
d = x + n, n is the distance the spring is compressed due to the weight of the ball
I am unsure how to solve for n.
F = (mgx)/(x+n) = -kn
I'm stuck here. It looks like a quadratic, but it looks incorrect.
Once I solve for n, I would have -kn, which is the restoring force.
Can someone help me? Thanks in advance!
Firstly , the reason for any and all deformation after collision is pretty much only dependent on momentum , and not force .
It depends . Which instant are we talking about ? If we speak of the instant at which it just touches the spring , it will be zero .
If we speak of the instant at which net force on the object is zero , yes , it will be equal to mg .
Your solution ... I can't understand what you have done .
Likes Samei
Correct.
Doesn't W = mg(x+n) ?
Also doesn't the spring do work on the mass as well?
Likes Samei
paisiello2 said:
Correct.
The solution seems wrong .
: [/B]W = KE2 - KE1
W = KE2 = mgx
and F = W/d
Substituting,
F = (mgx)/d
F=W/d only when the force is constant.Is the spring force constant here?
Likes Samei
No you are confusing the acceleration and deceleration phase. The "acceleration" that determines the impact force is the deceleration when it hits the ground not the acceleration on the way down (that's constant if you ignore air resistance).
Likes Samei
Perhaps continue with the COE theme and google "Energy stored in a spring".
Likes Samei
Sorry for the delay, but I'm back!
At the instant it touches the spring, then it will be zero. But what about after it compresses the spring? Since it pushes down the spring, I imagine it would gain more force. I wasn't sure of my equations either, but my main thoughts were of the fact that spring force (-kn) is equal to the force applied to it (the spring).
paisiello2 said:
Correct.
Because it compresses the spring, right? So it is x (height) and n (compressed distance). The spring does work through its restoring normal force.
Not sure about this, but I am going to say it acts like a "standard" spring, so spring constant is constant (k).
I just read a post regarding this, with the author summarizing it as the "fall doesn't kill you, but the deceleration (impact) does". I have since attempted to apply his strategy but found that I could not. I could use Impulse, but I am lacking t (time), and possibly other variables.Thanks to everyone who replied. I am still working on it. Right now, I am looking at using Impulse, although I am thinking Work-Energy Theorem should explain this. Am I overcomplicating this problem?
I really do appreciate the input, especially since my textbook does not explain this. :)
Stage spring constant is definitely constant.But the spring force is proportional to the compression in the spring.This means the force is not constant.Now F=W/d(This is what you've used.)is only valid for a constant force,hence it won't work here.
Oh, ok. That would explain why it did not seem right. So it looks like I'll have to use another set of equations then. I'll post what I'll find, which may take a moment or so. I'm looking at Impulse right now.
Alright. So, impulse was not the solution.
It turns out that I only need to use conservation of energy.
Here is my redo with same variables applied: mgx = Total E = KE1
Again, x is the height, m is the mass of the ball, and k is the spring constant as the given. n will be the compression of the spring.
At the instant it touches the spring, KE1 = mgn + 0.5kn^2 + KE2
KE2 = 0, since the ball stops at max compression.
KE1 = mgn + 0.5kn^2
It is a quadratic again. But solvable for n with given information.
Once I obtain this n, I simply plug it into -kn and I will have my restoring force.
I realize that there might be collision (inelastic/elastic) elements here. I just made up this problem to understand some topics so it is a bit flawed. Is the solution right, at least conceptually? I may ask another similar problem again if it helps.
KE1 = mgn + 0.5kn^2
Yes it is correct.
Likes Samei
Ellispson said:
Yes it is correct.
Thank you!
FAQ: Force of Falling Objects at a Height
What is the formula for calculating the force of a falling object at a certain height?
The formula for calculating the force of a falling object at a certain height is F = mg, where F is the force in Newtons, m is the mass of the object in kilograms, and g is the acceleration due to gravity (9.8 m/s^2).
What factors affect the force of a falling object at a height?
The force of a falling object at a height is affected by the mass of the object, the acceleration due to gravity, and the height from which the object is falling. Air resistance can also affect the force, but it is usually negligible for most objects.
Does the force of a falling object at a height change if the object is dropped or thrown?
Yes, the force of a falling object at a height will be different depending on whether the object is dropped or thrown. If the object is thrown, it will have an initial velocity which will change the force of impact when it hits the ground compared to an object that is simply dropped.
Can the force of a falling object at a height be greater than its weight?
Yes, the force of a falling object at a height can be greater than its weight. This occurs when the object is falling at a high speed, which increases the force of impact upon hitting the ground.
How does the force of a falling object at a height change as the height increases?
The force of a falling object at a height will increase as the height increases. This is because the object has more potential energy at a higher height, which is converted into kinetic energy as it falls and increases the force of impact upon hitting the ground.
