Force of gravity in relativity
In summary, calculating the force of gravity between two objects using Einstein's relativity theory does not involve directly calculating a force. Instead, one must determine the energy-momentum distribution and solve the Einstein Field Equations for the metric tensor. Then, using the geodesic equation, the motion of the objects can be calculated. Alternatively, the concept of extremal aging can also be used. This approach differs from using Newton's method and the formula f=g*m1*m2/r^2.
SUROJL
How can we calculate force of gravity between two objects using Einstein's relativity theory. Using Newton's method we can easily find attractive force between two objects by using formula
f=g*m1*m2/r^2
But how can we calculate the force using Einstein's equation?
Well, gravity isn't really a force in GR. What you do to figure out how things are going to move is this:
1. You figure out the energy-momentum distribution (i.e. a single spherical mass, a cloud of dust, etc.)
2. You solve the Einstein Field Equations for the metric tensor.
3. Assuming objects placed in this region of space are too small to change the spacetime very much, you use the geodesic equation (which you get from the metric) to calculate how they are going to move.
As elfmotat remarked, one generally doesn't calculate forces in General Relativity. It is possible, however, to calculate the reading on an accelerometer of an object that you hold "stationary" - using clocks and rulers local to said object. (You can use other clocks and rulers if you really want to, but the results are generally not very physically meaningful.)
Hopefully it's obvious why this is very similar to a force? It's rather like taking the reading of a scale for the "force" needed to hold the object stationary.
While in general it's hard to define what "hold stationary" really means, it's pretty easy in cases where you have a stationary metric - which more or less means in cases where none of the bodies is moving relative to any of the others.
If the reason you're interesting in calculating the force is to determine the equations of motion, it's worth nothing that the usual approach to calculating the equations of motion doesn't involve calculating forces or applying the Newtonian equation F=ma. Instead, one writes down the so-called "geodesic equations", which basically say that bodies move along extremal paths in curved space-time. "Extremal" paths are pretty much the shortest paths, though there are some subtle differences.
Another way of describing this is the principle of extremal aging (sometimes called maximal aging).
I hope this helps - I'm not sure of your background, so I tried to keep the answer very non-technical.
Related to Force of gravity in relativity
What is the force of gravity in relativity?
In the theory of general relativity, gravity is not considered a force but rather a curvature of spacetime caused by the presence of mass or energy. This curvature is what causes objects to move towards each other, giving the appearance of a force of gravity.
How does the force of gravity change in relativity?
In the theory of general relativity, the force of gravity is described as a warping of spacetime rather than a force between objects. This warping changes as the distribution of mass and energy in the universe changes, leading to changes in the gravitational force experienced by objects.
What is the role of mass in the force of gravity in relativity?
In the theory of general relativity, mass is one of the key factors that determines the curvature of spacetime and thus the strength of the force of gravity. Objects with more mass will have a greater effect on the curvature of spacetime, resulting in a stronger gravitational force.
How does the force of gravity in relativity differ from Newton's law of gravity?
Newton's law of gravity describes gravity as a force between two objects with mass. In contrast, the theory of general relativity views gravity as a curvature of spacetime caused by the presence of mass or energy. Additionally, general relativity takes into account the effects of time and space in its explanation of gravity, while Newton's law does not.
Can the force of gravity in relativity be explained by quantum mechanics?
While general relativity and quantum mechanics are two of the most successful theories in physics, they have not yet been successfully merged into a single theory. Therefore, the force of gravity in relativity cannot currently be fully explained by quantum mechanics. However, some theories, such as string theory, attempt to combine these two theories to provide a more complete understanding of gravity.
