Force of gravity on magnetically levitating object?
In summary, the conversation revolves around the concept of magnetic levitation and its potential effects on objects held together by non-rigid materials. The question posed is whether applying force on the top object, which has weaker magnets, would project force downward and make it more difficult to lift the bottom object with stronger magnets. The participants suggest clarifying the setup with a drawing.
KidSix
I just had a question regarding magnetic levitation..
If an object were to have a great enough magnetic force (via magnets of unequal strengths) to cause an object to be lifted while being held together by something that isn't rigid, like string, would putting force on the top object project force downward?
As in if I had higher grade magnets on the bottom object, would pressing down on the top object make the bottom object more difficult to lift?
Apologies if this is a bit vague or obvious. I have little experience with magnets.
hi there
welcome to Physics Forum
just having a little difficulty visioning what you are trying to do
how about drawing and posting a pic of your setup :)
Dave
Related to Force of gravity on magnetically levitating object?
1. What is the force of gravity on a magnetically levitating object?
The force of gravity on a magnetically levitating object is the same as the force of gravity on any other object, which is the weight of the object. However, since the object is being supported by magnetic forces, the weight may not have an effect on the object's position.
2. How does magnetically levitating an object affect the force of gravity?
Magnetically levitating an object does not affect the force of gravity itself. Gravity is a fundamental force that is always present and is not affected by other forces, such as magnetism.
3. Can the force of gravity be completely cancelled out by magnetic levitation?
No, the force of gravity cannot be completely cancelled out by magnetic levitation. While the object may appear to be floating, there is still a small amount of gravitational force acting on it. This is because magnetic levitation does not eliminate the object's mass, which is what determines the strength of the gravitational force.
4. How does the strength of the magnetic field affect the force of gravity on a levitating object?
The strength of the magnetic field does not directly affect the force of gravity on a levitating object. However, a stronger magnetic field may be able to hold up a heavier object, which can impact the overall balance of forces on the object.
5. Is the force of gravity the only force acting on a magnetically levitating object?
No, in addition to the force of gravity, there are also magnetic forces acting on a magnetically levitating object. These magnetic forces are what allow the object to remain suspended in the air without any physical support.
  • Electromagnetism
9K
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
