Force of spring equation problems
  • Thread starter Thread starter Elementard
    Force Spring
The discussion revolves around the correct interpretation of the spring force equation, specifically the distinction between displacement and distance. The equation Fp = Fs, with Fs = -kx, indicates that the force exerted by the spring is opposite to the direction of displacement, which is a vector quantity. Participants clarify that while the displacement can be negative, the extension of the spring should be expressed as a positive distance. The negative sign in the equation reflects the force's direction relative to the displacement, emphasizing that extension is measured in the same direction as the force. Overall, the conversation highlights the importance of understanding vector notation in physics problems involving springs.
Elementard
A light spring having a force constant of 145 N/m is used to pull a 6.00 kg sled on a horizontal frictionless ice rink. The sled has an acceleration of 1.80 m/s2.
By how much does the spring stretch if it pulls on the sled horizontally?
Fs= -kx
Fp= ma
m=6.00Kg
K=145N/m
a=1.80m/s
Fp=Fs
ma=-kx
(6)(1.8)=-(145)x
x=-0.0745m
I’m just wondering why I see some people make Fs=kx instead of -kx? isn’t the force of a spring a vector?
It is a vector. Say the sled is being pulled by the spring to the right. The spring stretches to the left which means that the displacement of the end of the spring is negative. One can formally write it as a one-dimensional vector in the negative direction using unit vector notation ##\mathbf{x}=-|\mathbf{x}|~\mathbf{\hat x}##. Then one can write a vector equation for the force, $$\mathbf{F}=-k\mathbf{x}=-k(-|\mathbf{x}|~\mathbf{\hat x})=+k|\mathbf{x}|~\mathbf{\hat x}.$$ The negative sign in the one-dimensional vector equation, ##F=-kx## indicates the direction of ##F## relative to ##x##. In this example with the spring to the right of the sled, if vector ##x## is to the left (spring extension) , vector ##F## is to the right; if vector ##x## is to the right (spring compression), vector ##F## is to the left.
Likes Elementard, topsquark and TSny
Thank you so much! This actually makes sense. :bow:👍
I just noticed that your answer is a negative number. You have solved for the displacement of the end of the spring which is a vector. This is incorrect. The problem is asking you by how much the spring stretches. This is a distance, i.e. the magnitude of the displacement, and a positive number.
Likes Elementard and topsquark
I would put it a little differently. "Extension" could be thought of as a distance or as a displacement.
Fs=-kx assumes the force being exerted by the spring at end A and the displacement of end A are being measured with positive in the same direction.
In this case, we are being asked for the extension, which is in the opposite direction to the force. Therefore the required answer is -x.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
