Za Kh
- 24
why is the tension force of spring conservative and tension force of rope not conservative ??
The force of tension in a spring or rope is the pulling force or stretching force that is exerted on the object. It is the force that keeps the object in tension and prevents it from collapsing or breaking.
The force of tension can be calculated using Hooke's Law, which states that the force exerted by a spring or rope is directly proportional to the amount of stretch or compression.
F = -kx
where F is the force of tension, k is the spring constant, and x is the displacement from the equilibrium position.
The force of tension is affected by the length, thickness, and material of the spring or rope. The force of tension also increases with the amount of stretch or compression applied to the object.
The force of tension increases as the length of the spring or rope is increased. This is because a longer spring or rope will require a greater force to stretch or compress it to the same distance as a shorter spring or rope.
Yes, the force of tension in a spring or rope can be greater than the applied force. This is because the spring or rope can store potential energy as it is stretched or compressed, which increases the force of tension within it.
