- #36
Jetflyer0
- 17
- 10
Thanks, I haven't learned much about this yet, but this was helpful.
Handy rule: if three forces are in static equilibrium they must act through a common point. But...CWatters said:I'll have to think about that. The angle of the reaction force at the ceiling isn't know
Yes, it follows from the torque equilibrium. It cannot be proved otherwise.CWatters said:My first instinct was to assume the angle of the reaction force at the ceiling is unknown, then prove its also 17 degrees. But how can you do that without writing a torque equation?...
Strictly speaking, it is not necessarily in the centre. The pressure distribution across the surface will not be uniform.srecko97 said:Wind does acts on every small piece of the foil, but the effect is the same if we assume it acts in one point? where is this point?
srecko97 said:Well, everything I know about ##F_{ceiling}## is that it is the only force acting on a foil besides ##F_{wind}## and ##F_g##. Its ##x## component ##F_{ceiling X} ## must be equal (size) to ##F_{wind}## and ##y## component ##F_{ceiling Y} ## must be equal (size) to ##F_g## in order to satisfy forces equlibrium. It is obvious then that the angle is the same. We really do not need to talk about torques here.
Suppose instead that the hinge has some frictional torque. Now the angle of the reaction force cannot be in line with the plate. So your assumption that the angle is the same must effectively be using a torque balance equation.srecko97 said:I do not understand why we need to talk about torque equilibrium. What is wrong with my deliberation:
I know the angle, I know the ##F_g##, I know the direction of ##F_{wind}##. There should be one more force to satisfy the forces equilibrium. I call this unknown force ##F_{ceiling}## ...(read the quote below)
You know the (free stream) direction of the wind. The presence of the foil is going to change it. The component of aerodynamic force parallel with the wind is drag, but you also have a perpendicular force component (lift).srecko97 said:I know the direction of Fwind.
