Force on a 3rd point charge due to 2 other point charges
In summary, the conversation discussed the problem of finding the net force exerted on a positive charge q1 by two other positive charges q2 and Q. The conversation included relevant equations and calculations to find the magnitude and direction of the net force. It was noted that there was an error in the direction of one of the force components, which was corrected. The conversation also revealed that both parties were using MasteringPhysics for their homework.
bumdass
Two positive charges q1 = q2 = 2.0 μC are located at x = 0, y = 0.30 m and x = 0, y = -0.30 m, respectively. Third point charge Q = 4.0 μC is located at x = 0.40 m, y = 0. What is the net force ((a)magnitude and (b)direction) on charge q1 exerted by the other two charges?
F = kq1q2/r2 (where k=9*109)
a2+b2=c2
polar coordinates (r, θ) can be converted to cartesian coordinates (rcosθ, rsinθ)
I got the right answer on the first part, but not on the second part. Feel free to skip the first part and look for the next bold heading
Since q1, q2, and Q are all positively charged, they will all repel each other. Since the question only wants the net force vector acting upon q1, there are only two forces that must be looked at - the force of q2 on q1 (I'll call this Fq2q1) and the force of Q on q1 (I'll call this FQq1).
To find those forces, the first relevant equation must be used. That equation takes two charges in C, not μC, so charges must be converted (e.g. 2.0 μC = 2*10-6 C). Since both q1 and q2 have the same charge, and they are .6m apart (because .3 - (-.3) = .6; they're both sitting on the y-axis so it's easy), it's pretty straightforward to find the (magnitude of the) force here:
|Fq2q1| = k*(2*(10-6))2/(.62) = 0.1
To find the other force, similar math is used, except that since the forces aren't both on the y-axis, one must use some basic trig (relevant equation 2). Plugging in the x and y values, one gets .32 + .42 = c2, and from there one finds the distance between Q and q1 is √(.09+.16) = √(.25) = .5
|FQq1| = k*4*(10-6)*2*(10-6)/(.52) = 0.288
After computing the magnitudes, I looked for their directions so that I could have 2D vectors to describe the forces. From q2 to q1, it is obvious that the direction is 90°. From Q to q1, there is some actual math. If you plot the two points, it's easy to draw a right angle triangle where the hypotenuse is between Q and q1, and the origin touches both legs. From there, one can see the angle from Q to q1 is arctan(.3/.4) ≈ 36.8699°
Fq2q1 = (|Fq2q1|cos(90°), |Fq2q1|sin(90°))
Fq2q1 = (0, .1)
FQq1 = (0.288*cos(36.8699°), 0.288*sin(36.8699°))
FQq1 ≈ (0.2304, 0.1728)
The two vectors were found
Armed with the vectors, finding the answer to the first question was easy:
Fq2q1+FQq1 ≈ (.2304, .2728)
√(.23042+.27282) ≈ 0.3571
That answer was marked correct. But now I need the angle of Fq2q1+FQq1. To compute that, I assume all you need to do is say tan = y/x, so then the angle should be:
arctan(.2728/.2304) ≈ 49.8164
That answer was marked incorrect. I don't understand why though
49.8164 degrees is in the wrong direction, so I just now tried 180-49.8164 and got the correct angle :DD
Wait, this is the same exact problem I had for my physics class. Are you using MasteringPhysics as well?
I don't think I should link you to the topic with my solutions because that would constitute "giving away the answer".
Aw man! I specifically googled the problem before posting it anywhere to see if anyone else could explain it, but I couldn't find anything :/
Nice ninja edit! I tapped on the link just in time to see your original question - yep, we had the same thing! I also have MasteringPhysics. You don't have to worry about giving away the answer, I already finished my MasteringPhysics homework this week.
Also, wow, I just now found the "Mark Solved" button :rolleyes:
You should check your force components with a simple diagram of the positions. You have a sign wrong.
Likes bumdass
All the same, it's not exactly kosher on here for me to do so.
Related to Force on a 3rd point charge due to 2 other point charges
1. What is the formula for calculating the force on a third point charge due to two other point charges?
The formula for calculating the force on a third point charge due to two other point charges is given by Coulomb's Law: F = k * [(q1 * q2) / r^2], where k is the Coulomb's constant, q1 and q2 are the magnitudes of the two point charges, and r is the distance between the two point charges.
2. How is the direction of the force determined in this scenario?
The direction of the force is determined by the direction of the electric field created by the two point charges. The force will act along the line connecting the two point charges and will be either attractive or repulsive depending on the charges of the two point charges.
3. Can the force on the third point charge be zero?
Yes, the force on the third point charge can be zero if the two point charges have equal magnitudes and opposite charges. In this case, the electric field created by the two point charges will cancel out and there will be no net force on the third point charge.
4. What is the significance of the distance between the two point charges in the calculation of the force on the third point charge?
The distance between the two point charges plays a crucial role in determining the magnitude of the force on the third point charge. As the distance increases, the force decreases and vice versa. This shows that the force between two point charges is inversely proportional to the square of the distance between them.
5. How does the force on the third point charge change if the magnitudes of the two point charges are increased?
If the magnitudes of the two point charges are increased, the force on the third point charge will also increase proportionally. This is because the strength of the electric field created by the two point charges is directly proportional to their magnitudes. Therefore, the force on the third point charge will be greater when the two point charges have larger magnitudes.
