hemalpansuriya
- 22
- 7
Charge will experience a rotating magnetic field around it. What will be electric field ( If any ) at the centre, generated by rotation of magnet ?
what are your thoughts? Which of Maxwell's equations probably applies here? Also, is this question for schoolwork?hemalpansuriya said:Summary:: A magnet is rotating in a circle facing its one of the pole towards the centre with radius R. If we put a charge q at the centre, what will be force on charge?
We can apply equation, curl E = -dB/dt to find electric field generated at the centre due to rotating magnet facing its one of pole at the centre. The question is not for homework, its my personal curiosity.berkeman said:what are your thoughts? Which of Maxwell's equations probably applies here? Also, is this question for schoolwork?
Sorry, but I deleted my post #4 as there's a mistake in it. I will post a correct solution - if it comes to me.hemalpansuriya said:Many thanks for your effort.
No, my mistake was to let ## (\nabla \times \bf E)_\theta = \partial E_r/\partial \theta - \partial E_\theta/\partial r = \omega B_0 ## or whatever I wrote.. Should have been obvious - the ##\theta## component of curl can't have any ##theta## in either derivative. Has to be ## \partial E_r/\partial z - \partial E_z/\partial r = \omega B_0 ##. But now I can't get a grip on the boundary values.Delta2 said:If ##\omega## is angular frequency of the rotation, then the rotating magnetic field at the center is given in cartesian components (if I am not mistaken) by $$\vec{B}=B_0(\cos\omega t\hat x+\sin\omega t\hat y)$$
Then we have to solve the PDE $$\nabla\times \vec{E}=-\frac{d\vec{B}}{dt}$$ which in fact is a system of three PDEs, because ##\frac{d\vec{B}}{dt}## will have two components (x and y) and we ll also get one more equation by equating the z-component of curl to 0 (I am not sure if we need this last PDE). We will have three unknowns (##E_x,E_y,E_z##) and 3 PDEs.
EDIT: Don't know if @rude man did the same mistake as me, but I completely neglected the generation of additional B-field according to Maxwell-Ampere's law. Maybe if ##\omega## is small we can safely neglect it.
Please checkout solution that I have tried,Delta2 said:If ##\omega## is angular frequency of the rotation, then the rotating magnetic field at the center is given in cartesian components (if I am not mistaken) by $$\vec{B}=B_0(\cos\omega t\hat x+\sin\omega t\hat y)$$
So, Ez is zero at the contre ( because x and y = 0 ). Right ?Delta2 said:After a bit more thought I end up that $$E_x=E_y=0, E_z=yB_0\omega\sin{\omega t}+xB_0\omega\cos{\omega t}$$ is one possible solution, I think it satisfies the original curl equation.
Yes.hemalpansuriya said:So, Ez is zero at the contre ( because x and y = 0 ). Right ?
Ok. Thank youDelta2 said:Yes.
