Force on a relativistic particle
In summary, the problem involves a particle of rest mass ##m_0## moving along a line and the question is what force is required to produce this motion. The solution requires the use of special relativity equations, specifically the velocity and acceleration equations in the rest frame and the equation for force in special relativity. The mistake made was using the classical definition of force instead of the relativistic definition.
omoplata
327
[/B]
A particle of rest mass ##m_0## is is caused to move along a line in such a way that its postion is $$x = \sqrt{b^2 + c^2 t^2} -b$$What force must be applied to the particle to produce this motion?
2. Homework Equations
The velocity of the particle as seen from the rest frame is ##v = \frac{dx}{dt}## and the acceleration is ##a = \frac{dv}{dt}##.
The mass of the particle as seen in the rest frame is ##m = \gamma m_0##, where ##\gamma = \frac{1}{\sqrt{1-\frac{v^2}{c^2}}}##.
Then the force should be ##F = m a##.
[/B]
Differentiating ##x##, I get ##v = \frac{c^2 t}{\sqrt{b^2 + c^2 t^2}}##.
So, ##\gamma = \frac{\sqrt{b^2 + c^2 t^2}}{b}##.
Differentiating ##v##, I get ##a = \frac{b^2 c^2}{(b^2 + c^2 t^2)^{\frac{3}{2}}}##.
So, ##F = \frac{m_0 b c^2}{b^2 + c^2 t^2}##.
The answer given in the book is ##F = \frac{m_0 c^2}{b}##. What did I do wrong?
Force in special relativity is generally defined as rate of change of relativistic momentum: ##\vec{F} = \frac{d\vec{p}}{dt}##, where ##\vec{p} = \gamma m_0 \vec{v}##. This is not equivalent to ##\vec{F} = m \vec{a}##, where ##m = \gamma m_0## and ##\vec{a} = \frac{d\vec{v}}{dt}##.
See
OK, I get the book answer now. Thank you!
Related to Force on a relativistic particle
What is the definition of force on a relativistic particle?
The force on a relativistic particle is a measure of the change in momentum of the particle over time. It takes into account the effects of both special relativity and classical mechanics.
How is the force on a relativistic particle calculated?
The force on a relativistic particle is calculated using the equation F=dp/dt, where F is the force, p is the momentum, and t is time. This equation takes into account the relativistic mass, velocity, and acceleration of the particle.
What is the relationship between force and energy on a relativistic particle?
The relationship between force and energy on a relativistic particle is given by the formula F=γ^3ma, where γ is the Lorentz factor, m is the mass of the particle, and a is the acceleration. This formula shows that the force and energy on a relativistic particle are directly proportional to each other.
Can a force on a relativistic particle exceed the speed of light?
No, according to the principles of special relativity, the speed of light is the maximum speed that any object can attain. Therefore, the force on a relativistic particle cannot exceed the speed of light.
How does the force on a relativistic particle change as its velocity approaches the speed of light?
As the velocity of a relativistic particle approaches the speed of light, the force on the particle approaches infinity. This is because the relativistic mass of the particle increases, making it more difficult to accelerate and resulting in a higher force.
