Force on a rod attached to a pivot
In summary, the conversation discusses a physics problem involving two rods with weights attached and a fixed pivot. The goal is to find the horizontal force on the right pivot when the weight is a certain distance from the ground. One person uses trigonometry to calculate the force while the other uses the concept of net force. They disagree on the answer and question where the horizontal force on the pivot comes from. The conversation ends with one person moving the discussion to a homework forum for more responses.
albertrichardf
165
Hello.
Can anyone help me confirm the following from the Feynman tips on physics:
The above diagram shows two rods, with a weight attached (the square). Each rod has a pivot attached, though the pivot on the left is fixed and cannot roll. The weight is 2 kg, and the rod is 0.5 m long. The question is to find the horizontal force on the right pivot when the weight is 0.4 m from the ground. Both rods exert a force such that the net vertical component balances the weight but for the following pretend that the rod with the moving pivot bears all the weight.
My reasoning is as follows: the weight exerts a vertical force on the rod. Part of this force is parallel to the rod and part is perpendicular. The rod transfers any parallel force to the pivot, and rotates under the effect of the perpendicular force. For our purposes, the perpendicular force can be ignored. The vertical component of the parallel force can also be ignored because that is balanced by the ground. The horizontal component of the parallel force is thus what is being looked for.
The parallel component is W cos ø, where W is the weight of the mass (2 * 9.8) and ø is the angle. The horizontal component is W cos ø sin ø. All this comes from trigonometry. Therefore the total horizontal force is about 9.4 N.However, Feynman reasons that the net force must be parallel to the rod. Because of the weight pushing onto the rod, the rod feels a vertical force, which it exerts on the pivot. The horizontal force on the pivot is also felt by the rod and must be such that the net force is directed parallel to the rod. In other words, the vertical and horizontal forces form right triangle with the net force as the hypotenuse. The horizontal force is then
W tan ø = 14.7
So I got 9.4 but he got 14.7. Can someone explain to me why I am wrong? Also in his explanation, if the rod feels only a vertical force due to the weight, where does the horizontal force on the pivot come from?
Thanks for answering
Related to Force on a rod attached to a pivot
1. What is the definition of force on a rod attached to a pivot?
The force on a rod attached to a pivot is the external force exerted on the rod at the pivot point, causing it to rotate around the pivot.
2. How is the force on a rod attached to a pivot calculated?
The force on a rod attached to a pivot can be calculated using the equation F = r * sin(θ), where F is the force, r is the distance from the pivot to the point where the force is applied, and θ is the angle between the force and the pivot.
3. What factors affect the force on a rod attached to a pivot?
The force on a rod attached to a pivot is affected by the magnitude and direction of the applied force, as well as the length of the rod and the distance of the force from the pivot point.
4. What is the difference between a pivot and a fulcrum?
A pivot is a fixed point around which an object rotates, while a fulcrum is a type of pivot specifically used in a lever system to support and balance the weight of the object being moved.
5. How does the position of the pivot affect the force on a rod attached to it?
The position of the pivot can affect the force on a rod attached to it by changing the distance between the force and the pivot point, which in turn changes the moment arm and can impact the magnitude and direction of the force.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
