- #36
voko
- 6,054
- 391
What is ##z'(0)## given the statement of the problem?
voko said:What is ##z'(0)## given the statement of the problem?
voko said:You are sure that ##m_1## is stationary initially, but not so sure about ##m_2##. Why?
voko said:I am not sure what you are trying to achieve now. You already have a general solution. All you need to do is use the initial conditions to fix two constants.
consciousness said:This calculus based approach is interesting but this question is easily solved by relative motion.
voko said:The statement of the problem has enough information on the velocities of both masses at t = 0. Just read it carefully.
How? A few hints would be great. :)consciousness said:This calculus based approach is interesting but this question is easily solved by relative motion.
consciousness said:Analyse the FBD of m2 w.r.t. m1.
The forces acting on it are-
1)F towards right.
2)kx where x is the extension in the spring towards left.
3)A pseudo force towards left as m1 is accelerating.
I think it was an SHM.
1)F towards right.
ehild said:m1 also performs simple harmonic motion. No sense to use a frame of reference attached to it.
You can describe the motion with respect to the CM. You know that the CM moves under the effect of the external force(s). It is F, a single constant force now, so the CM moves with uniform acceleration acm=F/(m1+m2). That means pseudo forces -m1acm and -m2acm acting on the masses. You need two equations again in order to describe the accelerations of the bodies.Dividing by the masses and subtracting the equations and introducing the variable z as before, you get the same differential equation as before.
The solution must be familiar to you: it is the same as that of a mass hanging on a spring. A constant force, added to the spring force. Instead of the hanging mass, you have μ=m1m2/(m1+m2) , the reduced mass of the two bodies. The solution is an SHM about a constant z.
ehild
ehild said:Teach me.
Pranav-Arora said:At maximum and minimum elongation, kinetic energy of system is zero.
Pranav-Arora said:Working in the frame of reference fixed to CM, let ##x_2## be the distance moved by ##m_2## towards right and ##x_1## be the distance moved by ##m_1## towards right. The force acting on ##m_2## are F (towards right) and ##m_2a_{cm}## (towards left).
From conservation of energy,
[tex]\frac{m_1F}{m_1+m_2}x_1+\frac{m_1F}{m_1+m_2}x_2=\frac{1}{2}k(x_1+x_2)^2[/tex]
Solving for ##x_1+x_2##, I get two values,
[tex]x_1+x_2=0, \frac{2m_1F}{k(m_1+m_2)}[/tex]
Pranav-Arora said:But is it possible to do this in the reference frame fixed to the ground?![]()
Pranav-Arora said:From conservation of energy
As we are analyzing wrt m1 it should bePranav-Arora said:Applying Newton's Second law on ##m_2##,
$$F-kx-m_1a_1=m_2a_2$$
No, I was calculating ##x_1+x_2##. I explained in my previous post what ##x_2## and ##x_1## are.voko said:I think you have sign errors in what follows. You are looking for ##x_1 - x_2##, not for ##x_1 + x_2##.
Pranav-Arora said:No, I was calculating ##x_1+x_2##. I explained in my previous post what ##x_2## and ##x_1## are.![]()
voko said:You defined both variables as distances toward right (from the center of mass, apparently). You are looking for the distance between the masses. That cannot be ##x_1 + x_2## with your definition.
