Force on charge particle with constant velocity
In summary, the conversation discusses the force acting between two equal charges moving with equal velocity, with a focus on the case where the angle between the velocity and the line joining the charges is 90 degrees. It is determined that in this case, the force between the charges in the lab frame is reduced due to a magnetic attractive force coming into play in the opposite direction to the electric repulsive force. The electric field is also changed, and this can be analyzed using either a relativistic force transformation approach or Zoki's equations.
elsafo
I have a problem. Anyone can help me?
Two equal charges q move with equal velocity v. What is the force acting between two charges?
The distance between charges is R and the angle between R and v is A.
Why would it be zero? What is the electromagnetic field associated with a moving point charge?
The electric force cancel each other and the magnetic field exerted by each charges are opposite but opposite direction. How?
I believe that what is sought is not the net force on the two-patricle system but the force on one of the particles induced by the other.
So how to solve it?
Start by trying to answer the second question of my first post.
elsafo said:
So how to solve it?
I'll deal just with the case of A = [itex]\frac{\pi}{2}[/itex], that is the velocity is at right angles to the line joining the charges. The easiest way to do this is to start in the frame of reference in which the charges are stationary. The force between them in this frame is simply the ordinary Coulomb's law force. Now transform this force to the lab frame, in which the charges are moving. The force transformation is very easy as
transverse force = change in transverse momentum / time taken to change.
The change in transverse momentum is the same in both frames, as it is a Lorentz invariant. The time is dilated by the usual gamma factor in the lab frame, compared with that in the frame in which the charges are at rest. So the force between the charges in the lab frame is, in SI units
[tex]\frac{\sqrt{1 - \frac{v^2}{c^2}} Q^2}{4 \pi \epsilon_0 d^2}.[/tex]
This reduction in the force can be interpreted as a magnetic (Ampère) attractive force coming into play in the opposite direction to the electric (Coulomb) repulsive force. But it's not as simple as that… As Zoki's equations show, the electric field is also changed. You'll note that Zoki's equations boil down to give the result I've derived above, in the special case of velocity at right angles to the line joining the charges. When the angle is not a right angle things get more complicated, but, again, you can either go for a relativistic force transformation approach (treating components parallel to, and transverse to, the velocity separately), or you can use Zoki's equations (having first derived them?)
Related to Force on charge particle with constant velocity
1. What is force on a charge particle with constant velocity?
The force on a charge particle with constant velocity is the product of the charge of the particle and its velocity. It is also known as the Lorentz force and is perpendicular to both the direction of motion and the magnetic field.
2. How is the force on a charge particle with constant velocity calculated?
The force on a charge particle with constant velocity is calculated using the equation F = qvB, where q is the charge of the particle, v is its velocity, and B is the magnetic field.
3. What is the direction of the force on a charge particle with constant velocity?
The direction of the force on a charge particle with constant velocity is perpendicular to both the direction of motion and the magnetic field. This means that it will either be in the upward or downward direction, depending on the orientation of the magnetic field.
4. How does the magnitude of the force on a charge particle with constant velocity change?
The magnitude of the force on a charge particle with constant velocity does not change as long as the charge and velocity remain constant. It is only affected by changes in the magnetic field strength or the direction of motion.
5. What is the significance of the force on a charge particle with constant velocity?
The force on a charge particle with constant velocity is significant because it is the basis for many important phenomena in physics, such as the Hall effect and the behavior of charged particles in a magnetic field. It also helps us understand the relationship between electricity and magnetism.
