Force on Electron Due to Two Charged Objects in an Electric Field
In summary, the conversation discusses the calculation of the magnitude and direction of the electric field at Point A, located a distance of d=0.09300 m to the right of Object Q1. The value is determined to be 5265 N/C to the right. Additionally, the conversation addresses the calculation of the force on an electron placed at Point A, which is found to be 8.42E-16 N to the left using the formula F = qE.
blue_lilly
36
Two charged objects are separated by a distance of L=0.4650 m as shown in the diagram.
Object Q1 has a charge of +5.250 nC. Object Q2 has a charge of +2.960 nC.
A) What is the magnitude and direction of the electric field at Point A, which is located a distance d=0.09300 m to the right of Object Q1?
B) If you were to place an electron at Point A, what would be the magnitude and direction of the force on the electron?
E= k (q/r^2)
F= (k*Q1*Q2)/ (r^2)
A) [ (8.99E9) ((5.25E-9)/(.09300^2) ] - [ (8.99E9) ((2.96E-9)/(.372^2) ]=
= 5265 N/C = 5.265E3 N/C to the right THIS ANSWER IS CORRECT
B) The charge on an electron is -1.6E-19. I am also assuming that i will need Coulombs Law to solve.
[(8.99E9)(5.25E-9)(2.96E-9)] / (.4650) =.64610E-7 to the left
This is not the right answer and I'm not sure why. AM i even using the right formula?
Any help would be greatly appreciated. Thanks!
You could use Coulomb's law and work directly with the charge values (you'd need to consider all the charges involved). But since you've already determined the electric field at point A you can use a different formula which relates the force on a charge due to the electric field...
The only equation I have that relates force and charge is E= F/q
(5.265E3)= F/(-1.6E-19)
(5.265E3)(-1.6E-19)= F
F= 8.42E-16 N to the left
Was that the equation you were talking about?
Yup. Most often you'll see it in the arrangement F = qE. It's analogous to the formula for force due to a gravitational field: F = mg. Makes it easy to remember :smile:
Likes 1 person
Oh, OK! That makes sense. Thank you for your help!
FAQ: Force on Electron Due to Two Charged Objects in an Electric Field
1. What is the force on an electron due to two charged objects in an electric field?
The force on an electron due to two charged objects in an electric field is given by the equation F = qE, where q is the charge of the electron and E is the electric field strength.
2. How does the distance between the charged objects affect the force on the electron?
The force on the electron is inversely proportional to the square of the distance between the charged objects. This means that as the distance increases, the force decreases and vice versa.
3. What is the direction of the force on the electron in this scenario?
The direction of the force on the electron depends on the charges of the two objects and the direction of the electric field. If the charges are opposite, the force will be attractive and if they are the same, the force will be repulsive. The direction of the electric field will determine the direction of the force.
4. Can the force on the electron be zero in this situation?
Yes, the force on the electron can be zero if the two charged objects have equal and opposite charges, resulting in an electric field of zero.
5. How does the charge of the electron affect the force in this scenario?
The force on the electron is directly proportional to the charge of the electron. This means that a larger charge will experience a greater force in the same electric field compared to a smaller charge.
