Leyic
- 6
Note: This is my first time using LaTeX. Any formatting advice would be appreciated.
Consider a homogeneous sphere of radius R_s made of a material that exerts a force obeying the inverse r-squared law (i.e. a particle of this material exerts a force on a test particle [tex]\vec{F}=\frac{K}{r^2}\hat{r}[/tex], where the vector r points from the particle to the test particle and K is a real number such that positive values are repulsive and negative values attractive). Next, consider a cylindrical hole of radius R_d that is removed from the sphere such that the axis of the cylinder passes through the center of the sphere. The hole passes completely through the sphere. Finally, consider a test particle arbitrarily placed on the axis of the cylinder a distance R from the center of the sphere. Determine the force felt by the test particle due to this configuration.
Due to the cylindrical hole, I decided to construct the sphere by integrating cylindrical shells. I defined the x-axis to be the axis of the cylinder and the y-axis to be orthogonal to the x-axis. Considering two particles equidistant from the test particle and the x-axis, I found the force on the test particle to be [tex]\vec{F} = \frac{2 K r_{x}}{r^3}\hat{x}[/tex], with [tex]r=\sqrt{r_{x}^2+r_{y}^2}[/tex] and r_x and r_y being the x- and y-components of the distance from the particles to the test particle, respectively.
Next, I revolved this about the x-axis to produce a ring of material of radius r_y. Now, [tex]\vec{F}=\frac{2 K r_{x}}{r^3}\hat{x} \pi r_{y} n[/tex], where [tex]n[/tex] is a number density term. I then note that the distance from the center of the sphere to the center of the ring is [tex]r_{d}=\sqrt{R_{s}^2+r_{y}^2}[/tex] and that r_x = R - r_d. I can then rewrite the force caused by the ring as [tex]\vec{F}=\frac{2 \pi K n (R-r_{d})\sqrt{R_{s}^2-r_{d}^2}}{(R^2+R_{s}^2-2 r_{d} R)^{3/2}}\hat{x}[/tex].
Next, I integrate over the length of a cylinder such that rings at the ends coincide with the surface of the sphere. Noting that r_d is the distance from the center of the sphere to a ring, I can show that the length of a cylinder of a given radius will be 2*r_d. The force is now [tex]\vec{F}=\int_{-r_{d}}^{r_{d}}\frac{2 \pi K n (R-r_{d}\prime)\sqrt{R_{s}^2-r_{d}^2}}{(R^2+R_{s}^2-2 r_{d}\prime R)^{3/2}}\hat{x}dr_{d}\prime[/tex], noting that the r_d in [tex]\sqrt{R_{s}^2-r_{d}^2}[/tex] should not be primed as this represents the radius and is constant for a given cylinder. Also, n is adjusted accordingly. Putting this into MATLAB, I get the solution [tex]\vec{F}=2 \pi K n \hat{x} \frac{\sqrt{R_{s}^2-r_{d}^2}}{R^2}(\frac{r_{d} R-R_{s}^2}{\sqrt{R^2+R_{s}^2-2 r_{d} R}}+\frac{r_{d} R+R_{s}^2}{\sqrt{R^2+R_{s}^2+2 r_{d} R}})[/tex].
Finally, I integrate over all cylinders in the sphere by integrating the cylinder half-length r_d from 0 to [tex]\sqrt{R_{s}^2-R_{d}^2}[/tex]. This results in the following equation:
[tex]\vec{F}=2 \pi K n \hat{x} R^{-2}(R \int_{0}^{\sqrt{R_{s}^2-R_{d}^2}} \frac{\sqrt{R_{s}^2-r_{d}^2} r_{d} dr_{d}}{\sqrt{R^2+R_{s}^2-2 r_{d} R}} - R_{s}^2 \int_{0}^{\sqrt{R_{s}^2-R_{d}^2}} \frac{\sqrt{R_{s}^2-r_{d}^2} dr_{d}}{\sqrt{R^2+R_{s}^2-2 r_{d} R}} + R \int_{0}^{\sqrt{R_{s}^2-R_{d}^2}} \frac{\sqrt{R_{s}^2-r_{d}^2} r_{d} dr_{d}}{\sqrt{R^2+R_{s}^2+2 r_{d} R}} + R_{s}^2 \int_{0}^{\sqrt{R_{s}^2-R_{d}^2}} \frac{\sqrt{R_{s}^2-r_{d}^2} dr_{d}}{\sqrt{R^2+R_{s}^2+2 r_{d} R}})[/tex].
To simplify this equation, I multiply the integrands by [tex]\sqrt{\frac{1/2R}{1/2R}}[/tex], and then let r_d = x, R_s = a, and (R^2+R_s^2)/2R = b. I then find that the integrals are of the following forms:
[tex]
1. \int_{A}^{B} \frac{\sqrt{a^2-x^2} x dx}{\sqrt{b-x}} \ \ \
2. \int_{A}^{B} \frac{\sqrt{a^2-x^2} dx}{\sqrt{b-x}} \ \ \
3. \int_{A}^{B} \frac{\sqrt{a^2-x^2} x dx}{\sqrt{b+x}} \ \ \
4. \int_{A}^{B} \frac{\sqrt{a^2-x^2} dx}{\sqrt{b+x}} \ \ \
[/tex]
I have not found any solutions to these integrals either by using MATLAB or by looking up integral tables. Nor can I see any other way of constructing the sphere that would properly account for the hole without further complicating the problem. Any advice on how I might move forward would be appreciated.
[tex]
[/tex]
