Force pressure variance after hole is plugged?
The discussion centers on the force required to insert a plug into a gushing hole versus the force needed to maintain the plug's position once inserted. It is suggested that the initial force to push the plug into the hole may differ from the force required to keep it in place due to the dynamics of fluid pressure. Participants are encouraged to consider the principles of hydraulics, particularly how pressure changes when a hole is plugged. The conversation also hints at exploring real-world applications, such as hydraulic rams, to understand these forces better. Ultimately, the key question remains whether it takes more, less, or equal force to maintain the plug compared to the force needed for insertion.
tmalcolm
TL;DR Summary
what is the force delta to plug a leak in a vessel vs the force to maintain the plug after it's in place?
There is a tall cylinder filled with water. And there is a 3 in diameter hole near the bottom and water is gushing out. (assume the cylinder is continually being re-filled from the top)
You work to plug the hole with a 10 inch long cylinder that is exactly the perfect diameter fit to plug the hole. (Assume a perfect fit with no wall friction as it slides into place)
It takes X amount of lbs of force to push the cylinder plug into the gushing hole to stop the leak.
Question -
How much force does it take to keep the plug in the hole once it has been pushed in vs the force required to get the plug in the hole initially?
(meaning, is it "easier" to keep the plug in the hole once it's inserted?) (equal to, less than, more than?)
Does it take more, less or equal force to push the plug deeper into the hole vs the amount of force to keep it one position?Thank you!
Tom
tmalcolm said:
Summary:: what is the force delta to plug a leak in a vessel vs the force to maintain the plug after it's in place?
Question -
Tom
Is this homework? What do you think the answer is/what have you tried?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
