member 428835
So I have worked through most of the problem and what I have so far is correct. Basically, I have force as a function of time which, when exerted on an object, moves the object up a 15 degree slant. Given two points in times, my question reduces to finding the total distance traveled within this time period. It should be known I have initial and final velocities.
work/energy seems useful here [itex]U=\Delta V_G + \Delta T[/itex]
i don't think i need impulse, or namely [itex]\int \sum F dt= \Delta G[/itex] as this deals explicitly with time, which I have already used to get the force function (though I could be wrong)
I was thinking [itex]U=\int F ds = m g sin(15) s + m {{V_2}^2}/2 - m {{V_1}^2}/2[/itex] where [itex]s[/itex] is the distance traveled I am looking for and the force function [itex]F[/itex] is changed to only account for forces other than gravity (since the [itex] \Delta V_G[/itex] term accounts for potential gravity.
but then, since [itex]F[/itex] is a function of time, I'm not sure how to proceed (if you need the force function I can give it, but it's kind of long)
I know both initial and final velocities [itex]V_1 , V_2[/itex]
Any ideas would be helpful! Thanks!
