I have read that The First Equation doesn't seem dimensionally correct to me, secondly, it does not say anything about the cutting speed or the blade design the blade material etc so i mean i can't go with it as baluncore said it's a complex thingNidum said:http://www.mymachineinfo.com/2015/06/paper-shredder-design.html
The force required for cutting process is the amount of force needed to overcome the resistance of the material being cut and create a clean cut. It is typically measured in units of Newtons (N) or pounds (lbs).
The force required for cutting process is determined by various factors, including the type and thickness of the material being cut, the sharpness and condition of the cutting tool, and the speed at which the cutting tool is moving. It can be calculated using specific formulas or measured using specialized equipment.
The force required for cutting process can be affected by the properties of the material being cut, such as its hardness and toughness, as well as the design and condition of the cutting tool. Other factors include the angle and speed of the cutting tool, the use of lubricants or cooling fluids, and the skill and technique of the person performing the cutting.
Accurately measuring and controlling the force required for cutting process is crucial for achieving precise and consistent cuts, reducing the risk of damage to the cutting tool or the material being cut, and improving overall efficiency and productivity. It can also help prolong the lifespan of cutting tools and reduce the potential for accidents or injuries.
The force required for cutting process can be minimized by using sharp and properly maintained cutting tools, choosing the appropriate cutting speed and feed rate, and selecting the right cutting tool for the specific material being cut. Additionally, using lubricants or cooling fluids, as well as implementing proper cutting techniques, can help reduce the force required for cutting process.
