Force required to change the direction
In summary, the question discusses the force required to turn a 1kg object moving horizontally at a constant speed of 10m/s to a 40 degree angle to the vertical. The answer to this question would require considering the change in momentum and impulse of the force applied in the x-y plane. However, as the object is moving at a constant velocity in the x-axis, the momentum along this axis does not change and thus the object cannot be turned to a 90 degree angle.
adjacent
63
I haven't studied forces acting on angles yet.
An object of mass 1kg is moving horizontally at a constant speed 10m/s.What is the the force required vertically to turn it 40 degrees to vertical?
Not a home work question
:confused:
:confused:
As I said,I haven't studied this yet.This is a homework like question. :smile:
Your question is not complete. Any amount of force, no matter how small will eventually change the direction by any desired angle. You need to specify a time interval.
(The force acting vertically is not enough. In order that there be no change in speed, the force must act perpendicular to the velocity vector so the force must change direction as the object does.)
(Surely you are not thinking that the direction will change instantaneously[/b] by 40 degrees? The path of the path of the object will curve to that direction.)
I see.Change in speed is not a matter.What's the equation relating force,time and angle?
I am not sure what you mean by the above (change in speed is not a matter).
If you assume constant speed, you could calculate the change in momentum between the two states: moving horizontally and moving at an angle of 40 degrees.
This change in momentum will give you the impulse of the force:
Δmv=F*Δt
where v and F are vectors and F is the average force.
Its better to think in terms of momentum.
F=dp/dt
F=dmv/dt (well, classically speaking...)
F=ma
Now to find a relation between F, t, θ and p.
F-force t-time θ-angle p-momentum
Take the initial direction of p (ie. p(0)) along x-axis ([itex]\hat{i}[/itex]))
Let force act in the x-y plane and [itex]\hat{i}[/itex] be along x axis.
F= a[itex]\hat{i}[/itex]+b[itex]\hat{j}[/itex]
Now at any time t-
p(t)=at+p[itex]\hat{i}[/itex]+bt[itex]\hat{j}[/itex]
∴tan(θ)=bt/(at+p)
θ=tan-1(bt/(at+p))
But equations like these are never used or necessary and usually derived to suit the needs.
F=dp/dt
F=ma
Now at any time t-
∴tan(θ)=bt/(at+p)
θ=tan-1(bt/(at+p))
What is a and b?
There is no force on the x axis.It's moving with a constant velocity.A force is applied on the y axis
Then a=0.
tan(θ)=bt/(p)
At θ=90° tanθ does not exist, therefore it can never turn to 90°
This happens because as there is no force along x-axis the momentum along it does not change. Then it follows that there is always some velocity acting along x axis.
Likes 1 person
FAQ: Force required to change the direction
What is "force required to change the direction"?
"Force required to change the direction" refers to the amount of force needed to change the direction of an object's motion. This can be in the form of a push or a pull, and is dependent on factors such as the object's mass and velocity.
How is force related to changing direction?
Force and changing direction are directly related. In order to change the direction of an object's motion, a force must be applied in the opposite direction of the current motion. The greater the force, the quicker the change in direction will occur.
What happens if there is not enough force to change direction?
If there is not enough force to change direction, the object will continue moving in its current direction. This is known as inertia, which is the tendency of an object to resist changes in its motion.
Can the force required to change direction be measured?
Yes, the force required to change direction can be measured using a variety of tools such as force meters or spring scales. This force is typically measured in units of Newtons (N) in the metric system.
What are some real-life examples of force required to change direction?
Examples of force required to change direction include a car turning a corner, a basketball player changing direction while dribbling, or a satellite changing its orbit around a planet. In all of these cases, a force must be applied to change the direction of the object's motion.
