Force required to keep arm in position
In summary: If the arm was at 80 degrees the answer would be 9kg x 80 = 960N x 0.33m = 382.4Nm If the arm was at 180 degrees the answer would be 9kg x 180 = 18,000N x 0.03m = 6,000Nm
DrowningKthnx
Lawrence is holding a 9kg dumbbell in his hand with his elbow flexed 90degrees. The horizontal distance from the center of mass of the dumbbell to the center of Lawrence's elbow is 33cm. The horizontal distance from the insertion of his elbow flexor tendons to his elbow is 3cm. If we ignore the mass of Lawrence's arm, how much Force do his elbow flexor muscles have to produce to hold his arm in this position?
T = F x r ?
I drew a diagram and labeled the known values. I am unsure if I should convert the 9kg dumbbell to Newtons (or if that is even right to do). The professor has previously converted cm to m, but I found nothing about that in our book. I converted 33cm to 0.33m and 3cm to 0.03m, but also don't know if that is right to do. Also, converted 90degrees to radians: 1.570rad, but once again unsure. I just need some guidance on if I'm doing Anything correctly and what step to take next.
Forces are measured in Newton so yes, you have to convert the mass of the dumbell to Newtons (noting of course that it is in a gravitational field).
The distances you can give in cm, m, yards, or light years - as long as you use the same units for both (resulting in the same unitd for torque, i.e., Ncm, Nm, Nyards, or Nly).
Show us your diagram.
There was no need to convert degrees to radians..
What can you tell us about the sum of torques about the elbow?
Is the 90degrees relevant to the equation?
I looked over another, similar problem and then did this:
T = 9kg x 33cm = 88.29N x 0.33m = 29.13Nm
Then
29.13Nm / 0.03m = 971.19N
But the other problem didn't have a value for degrees.
An explanation that demonstrates you understand the problem is more important than getting the correct numerical answer. Suppose you made a minor error in the calculation? If you only give an incorrect numerical answer you will score zero. If you explain your working you might still get most of the marks.
If I was to be picky I would point out that..
..is incorrect because the units don't balance.
Yes.
Could you answer the question if the arm was at 80 degrees?
If the arm was at 180 degrees what would the answer be? You should be able to answer that without doing any calculations.
FAQ: Force required to keep arm in position
1. What is the force required to keep an arm in a static position?
The force required to keep an arm in a static position depends on the weight of the arm and any additional weight being held, as well as the strength and endurance of the muscles involved.
2. How does the force required to keep an arm in position change with different arm positions?
The force required to keep an arm in position will vary depending on the angle and position of the arm. For example, holding an arm straight out to the side will require more force than holding it close to the body.
3. Does the force required to keep an arm in position differ between individuals?
Yes, the force required to keep an arm in position can vary between individuals based on factors such as muscle strength, body weight, and overall fitness levels.
4. Can the force required to keep an arm in position be reduced?
Yes, the force required to keep an arm in position can be reduced by improving muscle strength and endurance through regular exercise and proper form when performing tasks that require arm stability.
5. Is there a limit to the amount of force that can be exerted to keep an arm in position?
Yes, there is a limit to the amount of force that the muscles can exert without causing strain or injury. It is important to listen to your body and not push beyond its capabilities.
