Force required to lift a bar pivoting on one end
  • Thread starter mamcinty
  • Tags
    Force Lift
In summary, the person is looking for a way to use an RFID tag to remotely move a security bar on their sliding glass door. They want to use a linear actuator to mimic the action of pivoting the bar from horizontal to vertical. The person attempted to calculate the necessary counterweight for the bar to move, but decided to experimentally determine it instead. Torque is an important factor in this problem and they have provided resources for further understanding.
mamcinty
This is actually for a "hobby" project, not at all academically related, but I'm posting it here because I know it's very elementary. I'm just having more trouble with it than I should but it's been five years since my last Physics class so I felt like I partly have an excuse. ;-)
I have sliding glass doors at home and use a "charley" (security bar) to secure them. For reasons that would waste time to get into, I want to make it so that I can move this security bar into and out of place from outside my home using an RFID tag in my wallet. As shown in the attached drawing, the security bar is a piece of square tubular steel that is attached by a pivot to the right edge of the sliding door. When someone wants to open the door, they pivot the security bar from the horizontal to the vertical position. I want to mimic this action with a linear actuator.
In the drawing I have given the total length of the security bar (34"), a proposed attachment point of the linear actuator (12"), and the weight of the security bar (about 1lb).
I know that when the actuator starts to move (pick up the bar from its resting position) it must overcome gravity. This problem has been partially already answered here but I don't fully understand what is being said.
https://www.physicsforums.com/showthread.php?t=129054"
After spending a while trying to find the right way to calculate this, I actually decided to try and figure it out experimentally. I attached a piece of rope (12" from the pivot of the bar) and ran it through a pulley above the bar. Then I hung a jug of water on the other end and filled it until the bar moved upwards. After doing the calculation for the weight of water, I found that a counterweight of about 6lbs is needed for the bar to move. Does this sound right?
What is important is torque, force times a perpendicular distance, see:
http://www.google.com/search?hl=en&...&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi
http://en.wikipedia.org/wiki/Torque
In your case I took measurements off your diagram and assuming the drawing is roughly to scale we have the following torques about the bar pivot,
1 pound X 17 inches - force of actuator X 8 inches = 0
So with the bar in a horizontal position a force of about 17/8 pounds just keeps the bar in equilibrium. As the bar rises these numbers will change, that is another problem.
FAQ: Force required to lift a bar pivoting on one end
1. What is the definition of force required to lift a bar pivoting on one end?
The force required to lift a bar pivoting on one end, also known as the lifting force or effort, is the amount of external force needed to overcome the weight of the bar and move it in an upward direction.
2. How is the force required to lift a bar pivoting on one end calculated?
The force required to lift a bar pivoting on one end can be calculated using the principle of moments, which states that the sum of clockwise moments is equal to the sum of counterclockwise moments. The lifting force can be determined by multiplying the weight of the bar by the distance between the pivot point and the line of action of the weight.
3. What factors affect the force required to lift a bar pivoting on one end?
The force required to lift a bar pivoting on one end is influenced by several factors, including the weight of the bar, the distance between the pivot point and the line of action of the weight, the angle of the bar, and the coefficient of friction between the pivot point and the surface it rests on.
4. How does the angle of the bar affect the force required to lift it?
The angle of the bar has a significant impact on the force required to lift it. As the angle of the bar increases, the force required to lift it also increases. This is because the weight of the bar is distributed over a larger distance, resulting in a larger moment arm and a greater lifting force.
5. Can the force required to lift a bar pivoting on one end be reduced?
Yes, the force required to lift a bar pivoting on one end can be reduced by decreasing the weight of the bar, reducing the distance between the pivot point and the line of action of the weight, or by decreasing the angle of the bar. Additionally, using a lubricant at the pivot point can also reduce the force required to lift the bar by reducing friction.
