How Much Force is Needed to Lift a Shed Hatch?
In summary, the door will be hinged at the top long edge, open from the bottom long edge, and open out and up to a horizontal position. The door will require a lifting force and a force to keep the door in the open position. The lifting force will be determined by the weight of the door and the gravity here. The force to keep the door in the open position will be determined by the size of the door and the distance the door is from the ground.
kewsky
I plan to build a hatch door in one side of my shed. The plan is that the hatch door will be hinged at the top long edge. The hatch door will open from the bottom long edge. The hatch door will open out and up to a horizontal position (possibly slightly past horizontal). My question is what lifting force will be required to lift the door, what force will be required to keep the door in the open position, what forces (value and direction) will be exerted on the hinge during lifting and open. Sizes have not been decided yet so assume door size; horizontal length = L, vertical height = H, weight of door =W. Gravity here is normal. Any help, advice or insight would be appreciated.
An additional thought. Could a counterweight be added to aid lifting without building outside the shed?
Likes sophiecentaur
The counterweight can either be on a lever or on a pulley, pulling up the hatch. There are also airstruts (as on car hatchback doors) available.
The formula for the force, if the door starts hanging vertical, will, of course, where the handle is. If the handle is half way up the door, the force will be almost zero at the start and go to the value of the door weight when it's horizontal (if you are pulling it vertically) then it gets less when lifting further.
I think you will need to produce a diagram giving some idea of where and how the force will be applied to the door. Direction and point of application will have a huge effect on the actual force you need
I am not sure what you want do do but you might find https://www.sgs-engineering.com/help-advice/how-to-calculate-the-force-required-for-a-gas-strut/ helpful if you want to make the job easy for a person who's not too strong, even if the door is heavy.
Sorry to be Captain Obvious here, but why not just use a conventional door with side hinges? Is there some need for the hatch door to end up horizontal and high up?
What kinds of things pass through the open hatch? Just people and animals, or small equipment, or car-size vehicles, etc?
Who let the dogs out?
Related to How Much Force is Needed to Lift a Shed Hatch?
What is the force required to lift a hatch?
The force required to lift a hatch depends on several factors such as the weight of the hatch, the position of the hinge, and the force of gravity. It can be calculated using the formula F = m x g, where F is the force, m is the mass of the hatch, and g is the acceleration due to gravity.
How does the weight of the hatch affect the force required to lift it?
The weight of the hatch directly affects the force required to lift it. A heavier hatch will require more force to lift, while a lighter hatch will require less force. This is because the force needed to overcome the force of gravity is directly proportional to the weight of the object.
Does the position of the hinge affect the force required to lift a hatch?
Yes, the position of the hinge does affect the force required to lift a hatch. If the hinge is located closer to the edge of the hatch, it will require less force to lift it compared to a hatch with the hinge located further away. This is because a hinge closer to the edge creates a shorter lever arm, reducing the moment arm and thus the force needed to lift the hatch.
What are some other factors that may affect the force required to lift a hatch?
Aside from weight and hinge position, other factors that may affect the force required to lift a hatch include the type of hinge used, the friction between the hatch and its frame, and the angle at which the hatch is being lifted. These factors can all impact the amount of force needed to overcome the resistance and lift the hatch.
Is there a minimum force required to lift a hatch?
Yes, there is a minimum force required to lift a hatch. This is determined by the weight of the hatch and the force of gravity. In order to lift the hatch, the force applied must be greater than the force of gravity acting on the hatch. Otherwise, the hatch will not be able to be lifted.
  • Mechanical Engineering
