Is matter truly keeping pace with the expansion of space?
In summary: H^2 + \dot{H} However, this is true only for the flat (k=0) FRW metric. The Hubble parameter, H, is a constant for a given metric (or a given cosmology), and it is defined as the quotient of the scale factor at two different times. In other words, H is not affected by the dot. If you want to introduce a time dependence to H, you have to use the deceleration parameter, q, or the energy density, \rho, or the cosmological constant, \Lambda, or the curvature, k. These are the usual suspects used to describe the time
wolram
Dearly Missed
4,446
558
Difficult to explain this question but i will try, Space is expanding
and un gravitationally bound matter is carried along with it, so two
unbound bodies will get further apart, now gravity is a weak" force",
yet it can resist the expansion," i remember and astroid that has its
own tiny moon", so the force to resist expansion must be tiny, so
how do we know that when space expands it carries matter with
it at exactly the same rate," no slippage". and what "force" holds
matter to space, this again must be tiny, but non zero as matter
just would not move with space.
space if you like is the configuartion of matter so there's no force holding holding matter in postion (for start in one frame matter can be moving, but in it's rest frame it's zero), what is meant by space ex[anding is that the density is decreasing/the distance between objects is tending to increase where the rate is a function of distance.
sorry JSCD but what you have said is quirky and is no real explanation
there has to be some tie with space and matter to allow expansion to
work.
I'll try to explain better:
1) we know expansion is isoptopic because we observe iot to be isotropic and GR predicts taht in oour approcxiamtely isotropic universe expansion will be approximately isotropic
2) There is no identiifable force that could be accurately described as holding matter to space.
Given a point in space at a certain time, there is no absolute way of identifying that point in space with a point in space at a different time, so it is hard to make sense of your question and why space is best seen as the relationship between objectsrather than a phsyical object in it's own right.
If you translate the Hubble flow to a gravitational equivalent force, you will get a rough idea where mass density is insufficient to resist the Hubble flow.
By Chronos
You will have to be patient with me on this one, as i can not see
how matter moves with the expanding space if it is not somehow attracted
to it, "There must be an action to create a reaction", so why should
mass move just because the volume it lives in is increased, this
to me is a purely mechanical problem, ie no attachment no force
no movement.
I will be happy if there is no reasonable explanation for this question
as it shows the nonsensical explanation for expanding of"space time", if gravity can resist expansion then there must be something for it to resists against
Basically we are running into terminology / conceptual model diffrerences.
GR does not view gravity as being due to a force. Your question is phrased entirely in the notion that gravity is a force. The result is a conflict of viewpoints.
From the GR point of view, two particles in an expanding universe do not experience any mutual force. But neither does the Earth orbiting around the sun experienece a force. The particles (and the Earth) are simply following geodesics in space-time.
As long as the relative velocities are low, and the geometry of space is not too badly distorted (i.e. space is reasonably flat), you can re-interpret the curvature of space-time as a sort of force. You can do that with the Hubble expansion, too, because space in our universe is flat, as long as the velocities are low enough. Just look at the acceleration that two particles a distance 'd' apart would experience, and say that that acceleration is due to a "force".
The notion of "friction" between space and matter is probably just going to confuse things even further and is best dropped - realize that from the GR point of view, there is no force at all, and that the conversion into force is just sort of a translation from a GR way of thinking to semi-Newtonian way of thinking.
Here is (I think this is right) how to get an actual number for acceleration out of the Hubble constant.
We have v=Hr, where v is the relative velocity, H is the Hubble constant, and r is the distance.
Thus dv/dt = H dr/dt. But dr/dt is just v, which is H*r.
Thus dv/dt = H^2 r
The exact value of H is currentl being debated, I am using for this example H = 70 km/ megaparasec
Using google to do the conversion of units
google unit conversion
I get 5*10^-33 m/s^2 for r = distance = 1 km for this value of H
Thus dv/dt = H^2 r
Note that the Hubble parameter depends on time. Therefore:
[tex]\dot v = \dot H r + \dot r H[/tex]
[tex]a = H\dot r + H^2 r[/tex]
You would get the same result with the definition of H in terms of the scale factor R
[tex]H = \frac{\dot R}{R}[/tex]
But usualy the deceleration parameter is used to define the acceleration of expansion:
[tex]q = - \frac{R \ddot R}{\dot R^2} = - \frac{\dot H}{H^2} - 1[/tex]
The accepted value is around q ~ -0.6. This is an adimensional quantity and is usually the referred one when talking about acceleration of expansion.
You could measure also a "kind of acceleration" with [itex]\dot H[/itex]. However, the meaning of the first time derivative of the Hubble parameter is very different than the meaning of the deceleration parameter.
Thanks for the correction.
I'm not quite sure what the 'deacceleration' parameter you refer to is, I haven't run across it in my textbooks :-(.
I think that what I'm actually looking for is
[tex]\frac{\ddot{a}}{a}[/tex]
where a(t) is defined by it's role in the flat FRW metric
ds^2 = dt^2 + a(t)^2(dx^2+dy^2+dz^2)
I think you are calling what I call a(t) R(t) (?).
The above expression should give the ratio of the acceleration of two nearby geodesics to their distance. (It's the value of [tex]\mbox{R^x{}_{txt}}[/tex]).
However, upon review, I'm not really confident in how to calculate this expression from the Hubble constant.
A numerical example for the relative acceleration of two geodesics 1km apart in m/s^2 would be helpful, if it's not too much work.
Expansion can be looked upon as creating an effective spatial acceleration - if the Hubble sphere of radius R is considered to be uniformly expanding at velocity c, then the volumetric acceleration is 8(pi)R(c^2). Applying the divergence theorem, the effective acceleration acting outwardly by expanding space is 2(c^2)/R. For a central mass M exerting a gravitaional force on a mass wafted along by expansion, The balance point r would be in the neighborhood of (RGM/2c^2)^1/2
Thank you all for replies, but they don't really address the problem,
ie why do two ungravitationly bound bodies get further apart, when
no force has acted on them and as is said ,space is not exerting any
influence on them.
In a purely mechanical way a reaction has to start with an action, and
increasing a volume would have no effect on the distance between
two objects.
so if mass is not somehow tied to space, how does mass keep in step
with spatial expansion
It could be that space is expanding faster than we think it is, how
could we tell if the distance change between two objects is a % of
spacial expansion?
OK, the value you are talking about is the 00 component of the Ricci tensor:
[tex]R_{00} = -3 \frac{\ddot a}{a}[/tex]
(In my previous post I was using "R" instead of "a" for the scale factor, because I did use "a" before for the acceleration. But now I will use "a" for the scale factor). In terms of the Hubble parameter you can compute:
[tex]\frac{\ddot a}{a} = H^2 + \dot H[/tex]
This is the same as:
[tex]\frac{\ddot a}{a} = - H^2 q[/tex]
With q = -0.6 and H = 71 Km / s Mpc: 3.12 × 10-36 s-2. This is 3.12 × 10-33 m / s-2 for every km.
If you are not happy with the deceleration parameter q, you could use the fact that the 00 component of the Ricci tensor leads to the first Friedmann equation:
[tex] -3 \frac{\ddot a}{a} = \frac{4 \pi G}{c^2} (\rho + 3p) - \frac{\Lambda}{c^2}[/tex]
If one includes the cosmological constant as a dark energy with equation of state [itex]p = - \rho[/itex], this can be written as:
[tex] -3 \frac{\ddot a}{a} = \frac{4 \pi G}{c^2}(\rho + 3p) [/tex]
This should allow to calculate R00, considering 0.7 of matter and 0.3 of dark energy component (as fractions of the critial density).
If you assume only a dark energy content equal to the critical density you will see (using the equation of state and inserting the definition of critical density in the previous formula) that:
[tex]\frac{\ddot a}{a} = H^2[/tex]
Comparing with the second formula in this post, this means [itex]\dot H = 0[/itex] (the Hubble parameter does not change with time) and then your formula applies.
It is not clear to me is that this quantity R00 is the acceleration between two nearby geodesics. Could you elaborate on that?
I realize now you were not talking about R00, but about R1010, and R00 = R1010 + R2020 + R3030; all of them are equal in an homogeneous and isotropic space which explains the factor 3. Right? Anyway, could you explain how R1010 describes the acceleration for the geodesic deviation in this case?
That much I can do right away, I have yet to go over your previous responses. The basic idea is that the Riemann tensor can be physically interpreted in terms of tidal forces via the geodesic deviation equation.
The geodesic deviation equation
[tex]
\frac{d^2 x^a}{dt^2} = R^a{}_{bcd} u^b \xi^c u^d
[/tex]
gives the acceleration between a pair of points on neighboring geodesics. We need to specify each geodesic, which can be done by specifying a point in space, and a four-velocity, which defines the geodesic. The relative acceleration, though, depends only on the relative position. So we need to specify two four velocities, and one relative position.
Here u^b and u^d are the four-velocities (one four velocity for each geodesic), and [tex]\mbox{\xi^c}[/tex] is the spatial separation of the pair of geodesics.
[tex]
R^a{}_{bcd} u^b u^d
[/tex]
maps a vector [tex]\xi^c[/tex] that describes an spatial offset into a relative acceleration.
Now we assume that u^b and u^d both represent zero velocity (which means they are unit vectors in the time directon). This means we are interested in the tidal force on an object where both ends are stationary
Next, in this case, we are interested in the acceleration in the x direction introduced by a displacement between geodesics in the x direction. This mean that [tex]\mbox{\xi}[/tex] is a unit vector in the x direction.
The end result is that with these values for [tex]u^b, \xi^c, u^d[/tex], we in essence "pick out" one component of the Riemann
This is [tex]R^x{}_{txt}[/tex]
It gives the tidal force in the x direction due to an x offset - it's the x component of the "stretching" tidal force. By isotropy, the y and z stretching components will be equal.
Conveniently, we don't have to worry too much about scale factors with these combinations of superscripts and subscripts. If we scale everything in the x direction by a factor of .1, both the separation vector and the acceleration vector get scaled by the same amount, so the ratio remains constant. The only thing we need to worry about is that the time vector is scaled properly. Whle four velocities are always one in minkowski space they might not be one in a general metric.
In this case g_00 is -1, so there isn't a problem.
[add]
Note that [tex]R^y{}_{txt}[/tex] is zero in this case. If it existed, it would represent a tidal torque, rather than a tidal stretching force. The diagonal elements of [tex]R^a{}_{bcd} u^b u^d[/tex] are all stretching or compressing tidal forces, the off-diagonal components are all tidal torques.
Please feel free to debate theory, which has no bounds on reality,
im sure one day it will be realized that your ricci tensors are in a twist.
influence on them.
two objects.
spacial expansion?
Sorry to get technical on you, but before I can give you a correct numerical answer, I have to go through the equations to be sure that I'm computing it correctly myself. Besides, it is a good exercise (you've lucked out and raised an interesting question - sorry if you don't feel lucky).
If you are not interested in the numbers, but just the concepts, think of a baloon being inflated with little dots on it. (That's the standard anology).
As the baloon inflates, the dots get further apart. It might be possible to attribute the dots getting further apart to "forces", but it's better not to at this point.
The fact that the dots are moving further apart means that they have some relative velocity. The rate of change of this velocity will be their relative acceleration.
It turns out that the velocity and the acceleration will be proportioanl to distance, at least for two points which are reasonably close together. I.e. points which are twice as far apart will be moving away from each other twice as fast, and will be accelerating away from each other twice as hard as well.
It remains only to work out the exact value of the constant (the ratio of the acceleration to the distance). Dimensionally, it will be (meters/sec^2) / meters, or 1/sec^2. Roughly speaking, it should be something like 1 / (age of the universe)^2, but maybe there are some additional factors of 2, or 8 pi, or something-or-other involved. Hence the discussion.
Switching viewpoints back to the "force" point of view, you can interpret this physically as a "tidal force", othe same as the tidal force that the moon (and sun, for that matter) exerts on the Earth. Like the tidal force the moon exerts on the Earth, you can explain it in terms of matter if you like (in this case, you need to consider contributions from all the matter in the universe). You can also consider the tidal force to be due to the curvature of space-time (just as you can say that the curvature of space-time due to the moon and/or sun is what causes tides on the Earth).
I call it a tidal force because it is a stretching force (acceleration) that is directly proportional to distance (as long as the distance is small). This is exactly what a tidal force is. This is exactly what causes the Earth's tides.
It doesn't make a lot of sense (IMO) to attribute these tidal forces to friction. Friction is not really involved.
Look on the bright side - whatever replaces General Relativity will probably be in complexity and ease of calculation to GR as GR is to Newtonian gravity. We'll all be working out "simple" problems in GR wherever we can, saving the more complex calculations in the new theory for cases where the additonal complexity is needed.
Heck, we might even be in the unfortunate position of M-theory, where we can't actually calculate any numbers at all with the theory...
Yes, the factor of 3 comes from [tex]R^0{}_0 = R^0{}_{000} + R^1{}_{010} + R^2{}_{020}+R^3{}_{030}[/tex] the first of which is zero, and the last three of which are equal. (The ricci just contracts slots 1 and 3 of the Riemann).
The bottom line is that my first answer was off by a factor of -q, I should multiply it by .6, right?
OK, I'm totally convinced. H = [tex]\frac{\dot{a}}{a}[/tex] as you said
http://scienceworld.wolfram.com/physics/ExpansionParameter.html
and q, which I was not previously familair with is indeed, as you also said
[tex]-\frac{\ddot{a} a}{\dot{a}^2} = -\frac{\ddot{a}}{H^2 a}[/tex]
http://scienceworld.wolfram.com/physics/DecelerationParameter.html
So obviously [tex]\frac{\ddot{a}}{a} = -qH^2[/tex].
We can use either an argument similar to the one given in the first link above ("expansion parameter"), or direct calculation of the Riemann to find that the acceleration / unit distance is indeed [tex]\frac{\ddot{a}}{a}[/tex]
Actually measuring q is apparently difficult, though.
http://www.astro.psu.edu/users/rbc/a480/lec13n.pdf
Thank you, Hellfire, for an interesting and enlightening post.
Wolram - wrt your post 16 - It may be presumptuous to assert that the motion of material objects is not due to a force between space and matter - Einstein was convinced that you would get the same reactionary force if a mass remains at rest and the entire universe accelerated - as opposed to the reactionary force F = ma that is experienced when mass is accelerated wrt to space.
So if space if effectively undergoing acceleration due to volumetric expansion, there will be an outward component of acceleration. You can get the acceleration by double differentiating v = Hr or by taking the second derivative of the of the Volume with respect to time and then converting the volumetric acceleration to a surface integral via Gausses's Theorem as I illustrated in post #11. The two methods differ by a factor of 2, but the consequence is that space is diverging from every Hubble center at an accelerating rate
The problem with talking about the "flow of space" is that there is no known way to measure it. In fact, with currently accepted physics/ General Relativity, there is no preferred frame and the laws of physics are the same in all inertial frames. Therfore there is no way even in principle to talk about the "flow of space" as an actual measurable quantity according to General Relativity. One needs some other theory, like "yogi's weird ether theory" :-) to even talk about the flow of space as a measuarble quantity. [Possibly SCC might also alow one to talk about the "flow of space", but it is also a non-standard theory.]
You always run into problems when you attempt to give classical, or semi-classical analogies to modern concepts. Unfortunately, analogous models acquire a life of their own. The universe does not obey Aristotlean logic. That notion was dispelled 100 years ago - beginning with GR and further asserted by quantum theory.
Thankyou
pervect, yogi, all, you can at least see my point, and i can to some
extent see yours, the big problem as i see is lack of data, rulers, and
no matter how good the math is it get you nowhere without them,
i am not saying that the math is useless only that is a tool, not a
theory.
If you assume a zero cosmological constant, then there is nothing that can't be understood intuitively in terms of Newtonian physics (although you need GR to do the calculations).
Newton's 1st law: An object in motion tends to stay in motion
So why do you need anything to drive the expansion? Matter is moving apart now because it was moving apart in the past. Some matter got clumped together with nearby matter due to gravity, and so they stopped moving away from each other. Of course this leaves the question of how it all got started, but that's a different matter.
As for the rate of change of the expansion, remember that people were looking for a deceleration parameter. Deceleration is simply explained by the gravitational attraction between distant parts of the universe.
CHRONON
Part of the question is to know if matter is keeping pace with
spacial expansion, and how could we know if it is not, i think
it is only assumed to be, if it is not keeping pace it may make
no difference to the macro world, but then again it could.
My opinion is that its best not to think of space expanding at all. GR says that spacetime may be curved, but to go from this to the idea that space itself might be stretching or moving independently of the matter within it just seems to confuse things. I've written more about this at http://www.chronon.org/Articles/stretchyspace.html
Related to Is matter truly keeping pace with the expansion of space?
1. What is the expansion of space?
The expansion of space refers to the continuous increase in the distance between objects in the universe. It is a fundamental property of the universe and is believed to have started with the Big Bang.
2. How does matter relate to the expansion of space?
Matter, which makes up all physical objects in the universe, is affected by the expansion of space. As space expands, matter is also pushed apart, causing the universe to expand.
3. Is matter truly keeping pace with the expansion of space?
Yes, matter is keeping pace with the expansion of space. While it may seem like matter is being left behind as space expands, this is not the case. The expansion of space is happening at a constant rate, and matter is also expanding at the same rate.
4. How do scientists measure the expansion of space?
Scientists use various methods to measure the expansion of space, such as observing the redshift of light from distant galaxies, measuring the cosmic microwave background radiation, and studying the distribution of galaxies in the universe.
5. What implications does the expansion of space have on the future of the universe?
The expansion of space will continue to push galaxies farther apart, eventually causing the universe to become cold and dark. This is known as the "heat death" of the universe. However, the rate of expansion and the ultimate fate of the universe are still being studied and debated by scientists.
