Force Transform Applying: Question on a Specific Case
In summary, the conversation discusses a problem with applying the force transformation to a situation where an unbalanced force is exerted on an object in a different reference frame. The conversation explores the concept of four-vectors and the issue of having an x component of force in B's frame when there is none in A's frame. The question of whether the dot product term in the force transformation should be zero is raised. The person is seeking clarification and help in understanding this situation.
dan_b_
When I try to apply the force transformation (the 3 vector one) to the describe following situation, I find a result that I can't make sense of. Hopefully someone can tell me what I'm doing wrong. Suppose observers A and B are in inertial frames, and B travels in the +x direction relative to A. Object C is initially at rest relative to A, and is immediately next to A. In B's frame object C initially travels in the -x direction along with A.
Now consider what happens when an unbalanced force is exerted on object C in the +y direction when the force is described in the reference frame of A.
The object will accelerate in the +y direction when it is described in A's frame. I would think that the object must accelerate only in the +y direction in B's frame also (it cannot accelerate in the +x or -x direction), otherwise we would have a paradox. But once the object is moving in the +y direction relative to A and B, the relativistic transformation for the x component of force in B's frame suggests that the x component of force in B's frame will not be zero - even though the x component of force is zero in A's frame! This arises because the "power term" (the dot product of the force on object C in A's frame and the velocity of C in A's frame) that is present in the transformation will not be equal to zero. But this doesn't make sense to me. You can't have an x component of force in B's frame in this situation when there is no x component of force in A's frame; the object can't have an
x- component of acceleration in B's frame when it has no x-component of acceleration in A's frame. I suspect the only way out of this mess is that the dot product term in the force transformation must be zero for some reason, but I don't see why from the way that this thought experiment has been described. Can anyone please help?
I am not sure why you believe this. It is not true.
The reason is easier to see if you work with four-vectors instead of three-vectors. When C is moving in the frame of A then the four-force has a component in the time direction. This component is boosted into the x direction in the frame of B.
FAQ: Force Transform Applying: Question on a Specific Case
What is force transform applying?
Force transform applying is the process of converting a force vector from one coordinate system to another. This is commonly used in physics and engineering to analyze forces in different reference frames.
Why is force transform applying important?
Force transform applying is important because it allows us to accurately analyze and understand forces in different reference frames. This is crucial in many fields, such as mechanics, robotics, and aerospace engineering.
What is a specific case where force transform applying is useful?
One specific case where force transform applying is useful is in the analysis of forces acting on a moving object. By transforming the forces into the object's reference frame, we can accurately determine the net force and its effect on the object's motion.
How is force transform applying different from vector addition?
Force transform applying involves converting a force vector from one coordinate system to another, while vector addition involves adding two or more vectors together. In force transform applying, the magnitude and direction of the force remain the same, but the coordinates change. In vector addition, the magnitudes and directions of the vectors may change.
What are some common methods for force transform applying?
Some common methods for force transform applying include using rotation matrices, transformation equations, and vector projections. The specific method used depends on the coordinate systems involved and the type of force being transformed.
