Forced oscillations and ressonance
In summary, forced oscillations are vibrations caused by an external force, while resonance is a phenomenon where the frequency of the external force matches the natural frequency of the system, resulting in a significant increase in amplitude. Resonance can be harmful when it causes excessive vibrations, which can lead to damage or failure in various structures and machines. Real-life examples of forced oscillations and resonance can be seen in musical instruments, pendulums, and even natural disasters like earthquakes. It is important to consider the natural frequency of a system and prevent resonance to avoid potential harm.
williamsal
Hi friends, I will be right to the point.
On the book "Mechanics" by Landau & Lifgarbagez, chapter "Small Oscillations", section "Forced Oscillations":
1. What is the meaning of the term beta (phase constant) on the expression for the driven force, F(t) = f cos(gamma t + beta), how it relates to the initial configuration of the system? And why almost all other textbooks just write F(t) = f cos(gamma t) without the phase constant, in this case, "beta"?
2. How can we get, step by step, the expression for the linear dependence of the amplitude in the ressonance case as described by the equation 22.5. I read dozens of texts and books like Goldstein, Symon, Marion, etc but none could give a clear guidance on how to get this expression.
Thans
Williams
1) Admitting an arbitrary beta allows one to develop forumlas valid in cases for which the force at t=0 does not vanish. If others assume beta=0 they have probably just done it for purposes of simplification.
2) I'm not going to do it here, but it is simply a case of using L'Hopitals rule for determining the value of a limit that approaches 0/0. What they are doing is to determine the expression 22.4 in the limit where gamma -> omega. The limit can be obtained by differentiating with respect to gamma independently in the numerator and denominator, and then take the limit gamma -> omega. For more info, look up L'Hopitals rule e..g on Wikipedia.
FAQ: Forced oscillations and ressonance
What are forced oscillations?
Forced oscillations refer to the vibrations of a system that are caused by an external force or driving force. This force is usually periodic and can be either a constant or varying force.
What is resonance?
Resonance is a phenomenon that occurs when the frequency of the external force matches the natural frequency of the system. This results in a significant increase in the amplitude of the forced oscillations.
How does resonance affect the amplitude of the oscillations?
Resonance causes the amplitude of the oscillations to increase significantly. This is because the external force is continuously adding energy to the system at the same frequency as the natural frequency, resulting in a build-up of energy and a larger amplitude of the oscillations.
What are some real-life examples of forced oscillations and resonance?
Examples of forced oscillations and resonance can be seen in musical instruments, such as a guitar string vibrating in response to plucking or a tuning fork vibrating when struck. Other examples include the swinging of a pendulum, the vibrations of a car on a bumpy road, and the vibrations of buildings during an earthquake.
How can resonance be harmful?
Resonance can be harmful when it causes excessive vibrations in a structure, leading to damage or failure. For example, resonance can cause bridges to collapse, buildings to crumble, and machines to malfunction. It is important to consider the natural frequency of a system and avoid matching it with external forces to prevent resonance and potential harm.
