Forced to use symmetry to solve this double integral?
In summary, the author uses symmetry to integrate over only one semi-circle in the xy-plane and not the other, resulting in θ ranging from 0 to π/2 and a factor of 2 in front of the integral. The symmetry is due to the reflection of one portion of the hemisphere across the y-axis. The integral shown in the remark is not incorrect, but one must be careful when evaluating it to get the correct result, as √(x2) is not the same as x.
ainster31
158
http://i.imgur.com/d4ViHux.png
The author writes: "Now, using symmetry, we have..."
But what symmetry does the author use? Also, I got the integral as shown in the remark but why is it wrong?
The symmetry that's used is only to integrate over only one semi-circle in the xy-plane, and not the other. That's why θ only ranges from 0 to π/2, not all the way to π. That's also why there is a factor of 2 in front of the integral: because the integral over one semi-circle should be exactly equal to the integral over the other one. This is because the portion of the hemisphere is that is above one semi-circle is equal in volume to the portion that is above the other: one portion is just the reflection of the other one across the y-axis. That is the symmetry.
Alright, but why is the integral shown in the remark incorrect?
What did you get when you evaluated it? The integral isn't incorrect, but you have to be careful when evaluating it to get the correct result.
You have to be careful whenever you 'execute' a square root. √(x2) is not the same as x.
Related to Forced to use symmetry to solve this double integral?
What is symmetry and how is it used to solve double integrals?
Symmetry is a mathematical concept that refers to a balanced, regular pattern or arrangement. In the context of double integrals, symmetry is used to simplify the integration process by taking advantage of the symmetry of the function being integrated. This means that instead of evaluating the integral over the entire domain, it can be broken down into smaller, symmetrical regions, which can then be summed together to obtain the final result.
Why is it necessary to use symmetry in solving double integrals?
Using symmetry in solving double integrals is not always necessary, but it can greatly simplify the integration process and make it more efficient. By breaking down the integral into symmetrical regions, the number of calculations needed to obtain the final result is reduced, saving time and effort.
What are the different types of symmetry that can be used in solving double integrals?
The three types of symmetry that can be used to solve double integrals are: even symmetry, odd symmetry, and periodic symmetry. Even symmetry refers to a function that is symmetric about the y-axis, while odd symmetry refers to a function that is symmetric about the origin. Periodic symmetry refers to a function that repeats itself at regular intervals, such as a sine or cosine function.
Are there any limitations to using symmetry in solving double integrals?
While symmetry can be a useful tool in solving double integrals, it is not always applicable. Some functions do not exhibit any kind of symmetry, and in those cases, using symmetry to solve the integral would not be possible. Additionally, even when symmetry is present, it may not always simplify the integral to a significant extent.
Can symmetry be used to solve other types of integrals?
Yes, symmetry can also be used to simplify the integration process for single integrals and triple integrals. Just like in the case of double integrals, symmetry can help reduce the number of calculations needed and make the integration process more efficient.
16K
