AlfieD
- 68
Thanks in advance, sorry for the incompetency.
Please answer this question:were the forces for the third diagram (which I was unsure of), bigger than 700N (up arrow), and then smaller than 700 N (down arrow)?
It has a special name - what is it called?me said:...where does the downward force come from in each case?
There are four main forces acting on a sky-diver during skydiving: gravity, air resistance, lift, and drag. Gravity is the downward force that pulls the sky-diver towards the earth. Air resistance, also known as drag, is the resistance that air particles create as the sky-diver moves through the air. Lift is the upward force that is created when air flows over the shape of the sky-diver's body.
Gravity is the most significant force acting on a sky-diver during skydiving. It pulls the sky-diver towards the earth, causing them to accelerate towards the ground. The force of gravity also determines the speed at which the sky-diver falls, known as the terminal velocity.
Air resistance, also known as drag, is the force that opposes the motion of a sky-diver as they fall through the air. As the sky-diver's speed increases, so does the force of air resistance. This force eventually balances out the force of gravity, causing the sky-diver to reach a constant speed known as terminal velocity.
Lift is the upward force that is created when air flows over the shape of the sky-diver's body. This force helps to counteract the force of gravity, allowing the sky-diver to glide through the air. The shape and position of the sky-diver's body can affect the amount of lift generated.
During different stages of skydiving, the forces acting on a sky-diver may vary. At the beginning of the jump, the force of gravity is the most significant, causing the sky-diver to accelerate towards the ground. As the sky-diver reaches terminal velocity, the force of air resistance becomes equal to the force of gravity, resulting in a constant speed. When the parachute is deployed, the force of lift increases, allowing the sky-diver to slow down and control their descent.
