Forces between charged particles
In summary, the magnitude of the proton charge differs from the magnitude of the electron charge by 1 part in 109. To find the force between two copper spheres with a diameter of 1.7 mm and a distance of 1.7 cm apart, we must first calculate the total charge on each sphere. Assuming each copper atom has an equal number of electrons and protons, we can calculate the total negative and positive charge by using the molar mass and density of copper. The net charge on each sphere can be found by taking the difference between the total positive and negative charge.
PyMaster
Suppose the magnitude of the proton charge differs from the magnitude of the electron charge by a mere 1 part in 109.What would be the force between two 1.7-mm-diameter copper spheres 1.7cm apart? Assume that each copper atom has an equal number of electrons and protons.
Express your answer using two significant figures.
M = ρ V
ρcopper = 8920 kg/m^3
Vsphere = 4*pi / 3 * r^3
Molar mass of Copper = 63.5 g/mol
1 mol = 6.02*10^23
e=1.6*10^-19 C
k=9*10^9 N*m^2 / C^2
total negative charge = -e * #electrons
total positive charge = e * #protons
Msphere = (8920 kg/m^3)(4pi/3)(1.7/2 * 10^-3)^3 *1000g/1kg= 0.0229 g
0.0229 g Copper * 1/63.5 mol/g * 6.02*10^23 atoms/mol = 2.17 *10^20 atoms of Copper
total negative charge = -e*(29)*(2.17*10^20)
total positive charge = (29)*(-e+10^-9)
net charge = the sum of the two above
The charge is the same for both copper spheres, so just plug and chug after this point. I am getting the wrong answer. I am certain it has to due with the calculation of the total charge on each of the copper spheres.
I am not sure how to tie the "Suppose the magnitude of the proton charge differs from the magnitude of the electron charge by a mere 1 part in 10^9." part into the actual charge of the copper atoms.
Please help--I don't understand what they mean.
Saying that something differs by one part in x, where x is some number, means that one of them is larger (or smaller) by an amount that is 1/x of the other.
So in this case you might decide to let the proton charge be smaller than the electron charge by one part in 109, so then
$$q_p = \left(1 - \frac{1}{10^9} \right) q_e$$
Of course you could make the proton charge the larger one, too, if you wish.
You could also just work with the differences in the charges, since ##\Delta Q = (q_e - q_p) = \frac{1}{10^9}q_e##
Related to Forces between charged particles
What are forces between charged particles?
Forces between charged particles are the interactions that occur between two or more particles that have electric charges. These forces can either be attractive or repulsive depending on the type of charges involved.
What is the relationship between the magnitude of the charge and the strength of the force?
The strength of the force between two charged particles is directly proportional to the magnitude of the charges. This means that the greater the charges, the stronger the force between them.
How does the distance between charged particles affect the force between them?
The force between two charged particles decreases as the distance between them increases. This relationship follows an inverse square law, meaning that the force is inversely proportional to the square of the distance between the particles.
What is the difference between electrostatic and gravitational forces?
Electrostatic forces are the interactions between charged particles, while gravitational forces are the interactions between masses. The strength of the electrostatic force is much greater than the strength of the gravitational force, but both follow inverse square laws.
Can forces between charged particles be shielded or canceled out?
Yes, forces between charged particles can be shielded or canceled out by introducing another charged particle with an opposite charge. This creates a neutralization effect, resulting in a net force of zero between the particles.
12K
