Forces between the dipole and a point charge
In summary, the conversation discusses the calculation of the force experienced by an electric dipole with a given moment and a point charge located at a specific position. The solution involves using formulas for electric dipole strength, dipole moment, and force, as well as considering the dipole as consisting of two charges.
Albi Mema
We have an electric dipole with moment P=2*[10][/-5] pointing in x direction. What is the force experieced by dipole at origin when a point charge Q=3*[10][/-4] is located at (0.014 m ,0,0)
1. [E][/dipole]=(1/4π[ε][/0])(2p/r3)
2. p=qs
3. F=qE
4. τ=pEsinϑ
[/B]
I know that the [E][/dipole] can be calculated by the given formula. Then after that I can find force by F=E*r(distance between dipole center and point charge). The problem is that the point charge is located in the line along x. Does the formula change in this case. My book gives no explanation on the way the formulas are derived even thought I self learned some of them.
Hi Albi Mema and welcome to PF.
:welcome:
If you know about gradients, find the potential energy of the dipole in the field generated by the point charge and take the negative gradient to find the force.
If you don't know about gradients, consider the dipole as consisting of a negative and a positive charge separated by distance d, calculate the sum of the forces on the two charges then find an expression as d → 0.
Related to Forces between the dipole and a point charge
1. How do you calculate the force between a dipole and a point charge?
The force between a dipole and a point charge can be calculated using the formula F = k * q * (p/r^3), where k is the Coulomb constant, q is the charge of the point charge, p is the dipole moment, and r is the distance between the dipole and the point charge.
2. What is the direction of the force between a dipole and a point charge?
The force between a dipole and a point charge is always attractive, meaning it is directed towards the opposite charge. This is due to the inverse square relationship between the force and the distance between the charges.
3. How does the strength of the dipole affect the force between a dipole and a point charge?
The strength of the dipole, represented by the dipole moment, directly affects the force between a dipole and a point charge. A stronger dipole moment will result in a stronger force between the two charges.
4. What happens to the force between a dipole and a point charge if the distance between them increases?
If the distance between a dipole and a point charge increases, the force between them decreases. This is because the force is inversely proportional to the square of the distance between the two charges.
5. Can the force between a dipole and a point charge be repulsive?
No, the force between a dipole and a point charge is always attractive. This is due to the nature of the electric field, which always points towards the opposite charge.
