Forces of a basin surrounding a drain
  • Thread starter doneky
  • Tags
    Forces
In summary: Since you don't care to know the normal force, consider only the force balance equation tangentially to the surface.The centripetal force is a resultant, not an applied force. I.e. it is the ma part of the equation.So the equation becomes: ΣF=ma+mg?Yes, the equation becomes: ΣF=ma+mg.
doneky
A basin surrounding a drain has the shape of a circular cone opening upward, having everywhere an angle of 34.5° with the horizontal. A 28.5-g ice cube is set sliding around the cone without friction in a horizontal circle of radius R.
(a) Find the speed the ice cube must have as a function of R.
(b) Is any piece of data unnecessary for the solution? [YES]
(c) Suppose R is made two times larger. Will the required speed increase, decrease, or stay constant?
(d) Will the time required for each revolution increase, decrease, or stay constant?
If it changes, by what factor? (If it does not change, enter CONSTANT.)
(e) Do the answer to parts (c) and (d) seem contradictory? Explain.
Sum of the forces = mac = mv2/R
Attempted to draw a FBD and I still don't get it. From what I'm thinking, there's the force of gravity at an angle, and I guess that minus some sort of "normal" force would equal the centripetal force, but I don't think that's correct and I wouldn't even be able to get a normal force from that.
Do you mean, only a component of gravity? Which angle? The normal and the centripetal are not in the same direction either.
There are two approaches you can take.
1. Just go ahead and consider the force balance equation ΣF=ma in each of the horizontal and vertical directions.
2. Since you don't care to know the normal force, consider only the force balance equation tangentially to the surface.
I'm kind of confused now. I don't know if what I said made sense. I meant that if you did a force balance equation along the surface of the water, you would get the component of mg that goes along the surface as well as some opposite (which is what I meant by "normal" because I didn't know a better term), and I claimed the difference between these would be the centripetal force but now that I think about it I don't think I could do that and I don't think it'd work.
Horizontally, I can only imagine there being the inward centripetal force, and vertically I can only imagine the force of gravity. Is there something I'm missing?
You seem to have forgotten the normal force now. That has horizontal and vertical components.
You mentioned water in your last post... what water?
Related to Forces of a basin surrounding a drain
1. What causes the forces of a basin surrounding a drain?
The forces of a basin surrounding a drain are caused by gravity and pressure differentials. Gravity pulls water towards the drain, while pressure differentials between the water in the basin and the drain create a suction effect.
2. Why do the forces of a basin surrounding a drain increase as the water level rises?
The forces of a basin surrounding a drain increase as the water level rises because there is more water pushing down on the drain, creating a greater pressure differential. This results in a stronger suction force.
3. Can the forces of a basin surrounding a drain be affected by the shape of the basin?
Yes, the shape of the basin can affect the forces surrounding the drain. A deeper, narrower basin will create a stronger suction force compared to a shallower, wider basin. This is because the deeper basin will have more water pushing down on the drain, creating a greater pressure differential.
4. How do the forces of a basin surrounding a drain impact the flow of water?
The forces of a basin surrounding a drain can impact the flow of water by creating a suction force that pulls water towards the drain. This can help to increase the rate of drainage from the basin.
5. Are there any ways to decrease the forces of a basin surrounding a drain?
Yes, there are a few ways to decrease the forces of a basin surrounding a drain. One way is to increase the size of the drain, which will reduce the pressure differential and decrease the suction force. Another way is to decrease the water level in the basin, which will also reduce the pressure differential and suction force.
9K
  • STEM Educators and Teaching
