Forces, vectors and straight lines
In summary: Euclidean".In summary, Lines, including straight lines and circles, have zero thickness, zero cross sectional area and zero surface area.
Studiot
5,440
Where is it writ that forces must act in straight lines?
It's an observation of nature.
Newton was the first to put it into words.
Actually there's no real reason why an apple would fall straight down from a tree.
It's just that it works best to explain what we see around us.
I am aware that we count tangents as straight, but what of ring forces?
Magnitude and direction. Direction is a straight line.
Circular forces act in a straight line at any given moment in time (tangential) but that direction changes as a function of time. It's not pushing in all directions at once or it wouldn't go anywhere.
That's my point.
Ring forces act in every direction at once.
I've never heard of a ring force, I guess. What is it?
A 2D example would be the force within a journal containing a heated metal shaft.
A 3D example would be the membrane force in a balloon under pressure.
Each force term acts orthogonal to the membrane surface in a single direction. They're not all one force.
Why not, there is a continuous force all the way round the circle?
Would you also suggest that a circle is not one line, but an assembly of straight lines?
No; in differentation, a circle is an assembly of infinitesimal points.
Yes, continuous, so at each infinitesimal chunk of surface area:
[tex]P = \vec{A} \cdot \vec{F} [/tex]
the surface area vector (the "normal") and the force acting on that that surface have a single direction associated with them.
By that reasoning so is a straight (or any other) line.
2)I'm sorry what surface?
Studiot said:
1)
Very true.
I assume the surface of the balloon that you used as a 3d example.
The discussion had moved on to circles by then.
Whilst I'm sure we can regard circles and other lines, for some purposes, as just an assemblage of points I maintain that they have a existence all of their own.
All that has been offered here is to say that we can assign vectors to each point along a curve or across an area.
But for this to be possible, both the curve and area must have an existence separate from and the assigned vectors.
No answer has been offered to the question as to why a force cannot follow such a curve.
I was referring to the balloon for surface area.
In classical physics, spacetime is "smooth"
Related to Forces, vectors and straight lines
1. What is a force?
A force is a push or pull that acts on an object, causing it to accelerate or change its motion. Forces can be applied by contact (e.g. pushing a door) or at a distance (e.g. gravity).
2. What is a vector?
A vector is a mathematical quantity that has both magnitude (size) and direction. It is represented by an arrow, with the length of the arrow representing the magnitude and the direction of the arrow representing the direction.
3. How do forces and vectors relate?
Forces are often represented as vectors because they have both magnitude (e.g. strength) and direction. This allows us to use mathematical operations, such as addition and subtraction, to analyze and calculate the effects of multiple forces acting on an object.
4. What is the difference between a scalar and a vector quantity?
A scalar quantity has only magnitude (e.g. speed), while a vector quantity has both magnitude and direction (e.g. velocity). Scalars can be represented by a single number, while vectors require both a number and a direction.
5. How are forces and straight lines related?
Forces can act along straight lines, known as the line of action. This allows us to use the principles of geometry and trigonometry to analyze and calculate the effects of forces on an object in motion.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
