Forces when car wheels "lay rubber"
When a car accelerates and the wheels begin to slip, a counterclockwise torque must be applied to induce angular acceleration. The friction force at the wheels acts to the right, providing a counterclockwise torque that balances the applied torque. The maximum friction force occurs when it equals the product of the coefficient of friction and the normal force, allowing for net angular acceleration. The discussion clarifies that while the friction force is the only horizontal force on the car, the torque from the axle can be vertical, enabling the generation of a clockwise torque while maintaining balance. Overall, the interaction of these forces and torques is crucial for understanding the dynamics of slipping wheels during acceleration.
vparam
If the coefficient of static friction between tires and pavement is 0.65, calculate the minimum torque that must be applied to the 66 cm diameter tire of a 950 kg automobile in order to "lay rubber" (make the wheels spin, slipping as the car accelerates). Assume each wheel supports an equal share of the weight.
∑T = Iα
Suppose the car is moving to the right, so if the wheels roll without slipping, they are rolling clockwise. To get the wheel to slip, a counterclockwise torque would need to be applied to cause the wheel to have some angular acceleration. If the wheel was slipping, then the bottom of the wheel would move left with respect to the pavement, which means that friction would point to the right, providing a counterclockwise torque to offset the applied torque.
When the friction force maxes out, in other words F_f = μF_n, then an applied torque can exceed the frictional torque and cause net angular acceleration and the wheel to slip. In that sense, we set the two torques to be equal, and solve, which gets the correct answer according to the textbook.
However, I'm confused about why this works. If this is happening as the car accelerates as the problem suggests, wouldn't there need to be a net rightward force? Then, the translational velocity also increases, and can "keep up" with the increasing angular speed. Wouldn't this mean that the conditions laid out wouldn't work? In other words, how could this counterclockwise torque cause the car to accelerate to the right (more accurately, the force that causes the torque), while also getting the wheels to slip?
If you mean applied from the axle then you mean clockwise, I hope.
There is. The ##F_fs## on the tyres are the only horizontal forces on the car as a whole.
Yes, sorry that torque should be clockwise.
I think my main point of confusion is how would F_fs be the only force. Wouldn't there also need to be another horizontal force on the wheels/car to apply the clockwise torque?
Edit: After trying this out on paper, I realized that this torque generating force could also be purely vertical rather than horizontal. In this case, F_f would be the only force acting in the horizontal direction. Is this a valid interpretation of what you mean?
A torque is neither horizontal nor vertical. If the axle applies a clockwise torque to the wheel then the wheel exerts an anticlockwise torque on the axle. This pushes down the back of the car and lifts the front. So the normal forces on the wheels have a net clockwise torque on the car. As long as the front wheels stay in contact with the ground, this balances the anticlockwise torque on the car from the frictional forces.
What about the force that the axle exerts on the wheel? Would that need to be vertical in order for the net force on the wheel to equal the friction force, while still being able to generate a clockwise torque?
The forces from the wheels on the axle will be vertical forces to carry the weight of the car and horizontal forces to accelerate the car (car excluding wheels in each case).
Forces from axle on wheels are necessarily equal and opposite to those.
The torques are in addition to the forces.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
