dopey9
- 32
Forces/couple!
particle of mass m kilograms is acted on by two forces F[1] and F[2] with magnitudes 3*sqr-root 5 Newtons and sqr-root 5 Newtons and directions parallel to the vectors i+2j and i-2j respectively.
The particle is initially at a position given by the vector 2i+j
i was told to calculate the cartesian components of F[1] and F[2] and hence calculate the total force F[1] + F[2], acting on the particle in component form
MY SOLUTION
The vector i+ 2j has length sqrt{1^2+ 2^2}= sqrt{5}[
A vector in that direction, with length is just 3 times that: 3i+ 6j. That's the first force vector.
Similarly, the vector i- 2j also has length root5 so that is the second force vector. The total force, then, is F1+ F2= (3i+ 6j)+ (i- 2j)= 4i+4j
from there i need to show the couple of the total force about the point with position vector i is zero...so the total force is 4i+4j ......
I would appreaciate a explanation to how to tackle this Q, so I can do it myself...but I am assuming that it is a single force and a couple cannot be put in equilibrium by a single force so it must be zero? is that correct??
MY SOLUTION
