Forking multiple child processes in C++
  • Comp Sci
  • Thread starter md5fungi
  • Tags
    C++ Multiple
In summary: What am I doing wrong?In summary, the programmer is trying to split a file up into four parts, have four child processes assigned to a different part and sum that part, and then send the data to the parent process, which will then sum the four sums. However, the first child process does what it should, but the second, third, and fourth just print 0 for a sum. There must be some fundamental misunderstanding of the material the programmer has, but they can't figure out what that is.
md5fungi
24
Need to split a file up into four parts, have four child processes assigned to a different part and sum that part, and then send the data to the parent process, which will then sum the four sums.
Basic Fork() Knowledge and C++ Knowledge.
I keep on having the same problem, regardless of how I code the program. The first child process does what it should, but the second, third, and fourth just print 0 for a sum. There must be some fundamental misunderstanding of the material I have, but I can't figure out what that is.
Code:
#include <iostream>
#include <unistd.h>
#include <fstream>
#include <sys/wait.h>
#include <iostream>
#include <fstream>
using namespace std;
int main()
	int i,n=0,total_numbers=0,number, status, split_numbers;
	int previous_number[4];
	int my_number[4];
	int current_number[4] = {1,1,1,1};
	int sum[4] = {0,0,0,0};
	pid_t pid;
	ifstream myfile;
	myfile.open("test.dat");
	while (myfile >> number) {
		total_numbers++;
	split_numbers = total_numbers/4;
	myfile.close();
	pid = fork();
	for (i=0; i<4; i++) {
		if (pid == 0) {
			cout << "Child Process " << i << " " << getpid() << endl;
			my_number[i] = split_numbers * (i+1);
			previous_number[i] = split_numbers * i + 1;
				if (my_number[i] >= current_number[i] && previous_number[i] <= current_number[i])                      {
					sum[i]+=number;
					current_number[i]++;
			cout << sum[i] << endl;
			myfile.close();
			exit(0);
		} else {
			waitpid(pid, &status, 0);
			cout << "Parent Process " << getpid() << endl;
			pid = fork();
	return 0;
I can't figure out what you were trying to do with your while loop. But the reason the sum is zero is because the test
previous_number <= current_number
always fails, since the latter is always 1 and the latter is larger than 1. (If split_numbers is positive, anyways)
About your multi-threading, I have three questions about your setup:
(1) Was the assignment specifically to use fork()?
(2) How were you planning on having the children return their partial sum to the parent?
(3) Did you really intend to spawn children one at a time, rather than spawn all four at once?
I don't see how previous_number is always 1... When "i" increases, the value of previous_number should increase; I even cout'd the value to make sure. Then it's supposed to go through the file line by line until previous_number <= current_number, and then start summing until my_number >= current_number.
1.) Yes, the assignment was specifically to use fork.
2.) We are supposed to "pipe" the sums back to the parent, and then the parent is supposed to add them up.
3.) Actually, I intended to spawn all the children at the same time. I'd do this, I assume, by removing the "wait" command I have in there. This way it is easier to see if it's working, though.
Ohh... I figured it out. I'm supposed to increment current_number every time the loop reads the next line... but I was only doing it if it passed the test, which makes no sense..
Aha, I'm an idiot. Thanks for nudging me in the right direction!
Okay. This is a very sound approach to the problem -- I just wanted to make sure you weren't just making a mistake. (there is a wide variety of skill levels here, and fork() can be surprising to people who are used to things like java.lang.Thread or pthreads)
So, I have everything correctly implemented, except possibly my processes running concurrently. I got rid of the waitpid function, and it still seems like the order is Process 0, 1, 2, and then 3. Is there something else I need to do to make them run at the same time? Is there an easy way to tell?
Fork is a "slow" operation -- your first child probably finished its task before the second child got created.
If you want to see the concurrency, you could try adding a timed loop to the child task -- make child #n spin-wait for 5-n seconds or something like that, just to see if child 3 really finishes first.
Alright; thanks a lot for your help!
One last quick question: When I run my program in Linux, it doesn't quit automatically; I have to Ctrl-C out of the program. This is problematic, because I want to use "time ./a.out" to see how long my program runs, and I can only see that result after I push Ctrl-C, thereby giving me an incorrect result.
Related to Forking multiple child processes in C++
What is forking in C++?
Forking is a mechanism in C++ that allows a parent process to create multiple child processes. These child processes are exact copies of the parent process, but they have their own unique process IDs.
Why would I want to fork multiple child processes in C++?
Forking multiple child processes can be useful for tasks that require parallel processing. By creating multiple child processes, the parent process can distribute the workload among them, resulting in faster execution.
How do I fork multiple child processes in C++?
To fork multiple child processes in C++, you can use the fork() system call. This will create a new child process, which you can then use to call the exec() system call to execute a different program.
What happens to the parent process when I fork multiple child processes?
When you fork multiple child processes, the parent process continues to run alongside the child processes. However, the parent process can use the wait() system call to wait for the child processes to finish their execution.
Can I communicate between parent and child processes when forking in C++?
Yes, it is possible to communicate between parent and child processes when forking in C++. This can be achieved through various interprocess communication mechanisms, such as pipes, shared memory, or message queues.
