Form an equation in terms of x
  • Thread starter Gringo123
  • Tags
    Form Terms
In summary, the problem is to find the number of litres of each of the three different colours of paint used by Bob to create a new shade of paint by mixing black, red, and white paint. He uses x litres of black paint, 5 times as many litres of red paint as black paint, and 12 more litres of white paint than red paint. After producing 672 litres of the new shade of paint, an equation can be formed in terms of x and solved to find the amount of each colour used. It is simplest to use single "x" as the variable for all three colours. The amount of red paint is 5x and the amount of white paint is 5x + 12. After solving the
Gringo123
141
Can anyone give some help on how I should go about creating a formula for this problem?
Bob creates a new shade of paint by mixing black, red and white paint.
He uses x litres of black paint.
He uses 5 times as many litres of red paint than he uses of black paint.
He uses 12 more litres of white paint than he uses of red paint.
Altogether he produced 672 litres of the new shade of paint.
Form an equation in terms of x and solve it to find the number of litres of each of the three different colours of paint used.
Do I use different letters for the red and white paint or is it ok to call them 5x and 5(x + 12 )
You could do it either way but it is simplest to use the single "x". Assuming that you mean x to be the amount of black paint in litres (and you should always state that explicitely), then the amount of red paint is 5x and the amount of white paint is 12 litres more that that, 5x+ 12, NOT 5(x+ 12).
Now add those together and set it equal to 672. Solve that equation for x and then find x+ 12 and 5x+ 12. Write the answers in full sentences- "He used 24 litres of black paint", not "x= 24" (That is not necessarily the correct answer, I just made it up.).
FAQ: Form an equation in terms of x
What does it mean to "form an equation in terms of x"?
Forming an equation in terms of x means to write an equation where the variable x is the only unknown quantity. This allows us to solve the equation for x and find its numerical value.
How do I form an equation in terms of x?
To form an equation in terms of x, you need to identify the given information and variables in the problem. Then, use algebraic operations to manipulate the equation until x is the only unknown quantity on one side of the equation.
Why is it important to form an equation in terms of x?
Forming an equation in terms of x allows us to solve for the value of the variable and find a specific solution to the problem. It also helps us understand the relationship between different variables in the equation and make predictions or solve for other values.
Can I form an equation in terms of any variable?
Yes, you can form an equation in terms of any variable. However, it is common to use x as the variable, especially in mathematics and science, because it represents the unknown quantity.
What are some strategies for forming an equation in terms of x?
Some strategies for forming an equation in terms of x include identifying the given information, writing it in terms of x, using algebraic operations to manipulate the equation, and checking your solution by plugging in the value of x into the original equation.
