Form of all mathematical statements
In summary, while not all mathematical assertions may take the form of a → b, they can usually be expressed in that form in a more formal and precise manner. Axioms may not appear to use entailment symbols, but they are the starting points that lead to logical implications. Ultimately, mathematics is a deductive science based on implications.
Mr Davis 97
1,462
44
I am reading Real Mathematical Analysis by Pugh, and he claims that "All mathematical assertions take an implication form a --> b."
However, is this really true? For example, the assertion, "There exist infinitely many prime numbers," doesn't seem to take the if-then form.
Mathematics news on Phys.org
It is not true for axioms.
For example, of the Zermelo-Frankel axioms that are the foundation of set theory, one of them, the Null Set axiom (##\exists x\neg\exists y(y\in x)##) does not use an entailment symbol ##\to##.
Another foundational example is the Peano axioms that found the natural numbers. The first one (##0\in\mathbb N##) contains no entailment.
However, nearly all theorems (as opposed to axioms) have the entailment form. They typically have a set of premises, and a conclusion that follows from the premises - therefore an entailment. For example, every continuous function on a compact set is bounded. This may be restated as 'IF f is a function that is continuous and has a compact domain THEN f is bounded'.
The statement about prime numbers is in entailment form, in the way it is usually proved and presented, which is:
'IF ##x## is prime THEN there exists an integer ##y>x## that is also prime'
The statement 'there are infinitely many primes' sounds like it contains no entailments, but when we interrogate the definitions of 'prime' and 'infinitely many' we will probably find that we need entailments to make those definitions. For instance, a common definition of ##p## being prime is:
\forall x\forall y\ ((x\in\mathbb N\wedge y\in\mathbb N \wedge x\cdot y=p)\ \to\ (x=p\vee x=1))$$
However, an example of a theorem that does not use entailment is
1+1=2
which, in the language of Peano, is
$$S(0)+S(0)=S(S(0))$$
You can always force every true statement ##a## into that form by writing ##true \Rightarrow a##.
##x=y## can be written as ##z=x \iff z=y##.
Possible? Yes. Useful? No.
In general, mathematics is a deductive science: a conclusion of a truth from another truth, i.e. an implication. Physics, e.g. is a descriptive or inductive science.
Axioms are the framework, in which deductions take place. They describe the setting and are as such no implications, as gravitation is the setting and not the force. You have to start somewhere, if all is written as an implication. And these starting points are called axioms: assumed truths.
The example ##\{true\} \longrightarrow A## is the hidden case of axioms, because the truth we started at is either an axiom itself, or an earlier implication from a previous truth. It isn't all of a sudden just there.
"There exist infinitely many prime numbers" is an implication in other words. It really means the following:
If we consider numbers to be the elements that obey ...<arithmetic axioms> ... and call a number prime, if ... <definition of prime> ... then the set of natural numbers contains infinitely many of them.
Thus all three examples do not disprove Pugh, rather explain how it should be read. The kernel of his statement is true, as it was probably meant to describe the nature of mathematics, e.g. in contrast to physics, and not the difference between axioms and implications.
As the mathematical statements become more formal, they may tend to be expressable in the form a → b. Not all statements are formal and even the formal statements may be expressed in different ways.
The original example "There exist infinitely many prime numbers," can be expressed in the form a → b. :
If S is the set of prime numbers, then the cardinality of S is ##\aleph##0
Related to Form of all mathematical statements
1. What is the form of all mathematical statements?
The form of all mathematical statements is typically written as a mathematical equation or expression, consisting of numbers, variables, and mathematical operations such as addition, subtraction, multiplication, and division.
2. Why is it important to understand the form of mathematical statements?
Understanding the form of mathematical statements is crucial in solving mathematical problems and equations accurately. It allows us to properly interpret and manipulate the numbers and variables involved in the statement in order to arrive at the correct solution.
3. What are the different types of mathematical statements?
There are several types of mathematical statements, including algebraic equations, geometric theorems, and logical statements. Each type has its own form and rules for solving and proving.
4. How can I determine the form of a mathematical statement?
To determine the form of a mathematical statement, you can break it down into its components, such as numbers and variables, and identify the mathematical operations involved. You can also consider the context in which the statement is presented and what it is trying to convey or solve.
5. Can the form of a mathematical statement be changed?
Yes, the form of a mathematical statement can be changed by using properties and rules of mathematics, such as the commutative and associative properties, to rearrange and simplify the expression. However, the underlying meaning and solution of the statement will remain the same.
  • General Math
