A Form of energy momentum tensor of matter in EM fields
The discussion centers on the lack of consensus regarding the energy-momentum tensor for polarizable media in electromagnetic fields, tracing back to various foundational papers from Kluitenberg to more recent works. Different sources, such as Davison Soper and A.M. Anile, present conflicting expressions for the tensor, with some modern formulations appearing more simplified. Notably, recent papers on magnetohydrodynamics propose specific forms for the matter and field tensors, yet discrepancies remain in symmetry and terms used. The participants agree that while there is no unified form for the matter or field tensors individually, the combined matter-field tensor is well-defined. This ongoing debate highlights the complexities in accurately describing the energy-momentum tensor in these contexts.
Sunny Singh
TL;DR Summary
I'm trying to understand if there is a scientific consensus on the form of the energy momentum tensor for a polarizable matter in electromagnetic fields
I've been reading about the form of the energy momentum tensor for a polarizable medium in electromagnetic fields and i'm not sure if there is a scientific consensus on its form. Starting from the series of papers by Kluitenberg in the 1950s to works by Israel and Dixon in the 70s... various sources give various expressions for the form of the energy momentum tensor. In "Classical Field Theory" by Davison Soper, there are 7 different contributions to the energy momentum tensor while in "Relativistic fluids and magnetofluids" by A.M.Anile, there are four such terms which don't seem to agree with others' works. More recent papers on magnetohydrodynamics use the following form of the matter + field ##T^{\mu\nu}##: $$ T^{\mu\nu} = \varepsilon u^\mu u^\nu-P \Delta^{\mu \nu}-\frac{1}{2}\left(M^{\mu \lambda} F_\lambda{ }^\nu+M^{\nu \lambda} F_\lambda{ }^\mu\right) -F^{\mu \lambda} F_{\;\lambda}^\nu+\frac{g^{\mu \nu}}{4} F^{\rho \sigma} F_{\rho \sigma}$$
And some papers like https://arxiv.org/pdf/0812.0801 uses $$ T^{\mu\nu} = \varepsilon u^\mu u^\nu-P \Delta^{\mu \nu}-M^{\mu \lambda} F_\lambda{ }^\nu -F^{\mu \lambda} F_{\;\lambda}^\nu+\frac{g^{\mu \nu}}{4} F^{\rho \sigma} F_{\rho \sigma}$$
Which doesn't even look symmetric. And according to "Dynamics of Polarisation" -- General Relativity and Gravitation, 9, 5 (1978) by Israel, the last term gets replaced by ##\frac{g^{\mu \nu}}{4} F^{\rho \sigma} H_{\rho \sigma}## when minkowski tensor is considered. These modern expressions look way more simplified than some of the older sources' forms.
My question is if there is a scientific consensus on what the energy-momentum tensor of such a polarizable fluid in electromagnetic fields look like. Any help or direction will be greatly appreciated since i'm thoroughly confused now.
The metric i used is the westcoast metric and ##\Delta^{\mu\nu}=g^{\mu\nu}-u^\mu u^\nu## is the projection operator orthogonal to fluid flow.
Frabjous said:
I was also going to suggest that exact same paper.
The bottom line is that there is no agreed upon form for either the matter tensor or the field tensor separately. But the matter+field tensor is well defined
Likes Sunny Singh and Frabjous
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
