Form of Kruskal-Szekeres Completion
  • Thread starter Airsteve0
  • Tags
    Form
In summary, The conversation discusses the process of deriving the form of the Kruskal-Szekeres form of the Schwarzschild metric and the use of several formulas and the Lambert W. function. The speaker also mentions having trouble with subbing in and working with their own attempt at the equation for 'r'. They are then advised to repeat the process for dt and plug them into the metric. The link to their professor's paper is also provided.
Airsteve0
83
In my general relativity class my professor derived the form of the Kruskal-Szekeres form of the Schwarzschild metric using several formulas without actually going through the algebra. I am trying to prove the answer using these formulas but I am having some trouble, especially using the Lambert W. function. In the file I have attached, you can see that equation (9) is the final result from the changes made in the previous equations. In my attempt I tried taking the derivative of the equation for 'r' and arrived at what I have shown below. However, when subbing this in and working with this I don't feel I am making progress. Any assistance is greatly appreciated, thanks.
[itex]dr=2m\frac{dL}{dz}dz[/itex]
where [itex]z=\frac{-uv}{e}[/itex]
The link for my professor's paper is at this link, http://arxiv.org/pdf/1202.0860v2.pdf , but I will also include the .pdf
  • Kruskal-Szekeres.pdf
That seems like a proper mess :)
But basically what you have is
[tex] r = 2m(\mathcal{L}(1+\Psi(u,v))) [/tex]
so
[tex] dr = \frac{\partial r}{\partial u} du + \frac{\partial r}{\partial v} dv = ... = \frac{2m \mathcal{L}}{1 + \mathcal{L}} (du/u + dv/v) [/tex]
or something like that; I'm too lazy to do the work :) Then repeat for dt. Then you just plug them into the metric and pray everything works out.
got it, thanks!
FAQ: Form of Kruskal-Szekeres Completion
What is the Form of Kruskal-Szekeres Completion?
The Form of Kruskal-Szekeres Completion is a mathematical concept used in general relativity to extend the Schwarzschild solution to describe the complete spacetime of a black hole.
How does the Form of Kruskal-Szekeres Completion differ from the Schwarzschild solution?
The Schwarzschild solution only describes the exterior of a non-rotating, uncharged black hole, while the Form of Kruskal-Szekeres Completion extends this solution to include the interior region of the black hole.
What is the significance of the Form of Kruskal-Szekeres Completion in general relativity?
The Form of Kruskal-Szekeres Completion allows for a complete description of the spacetime of a black hole, including its singularity, and allows for easier calculations and understanding of the properties of black holes.
Can the Form of Kruskal-Szekeres Completion be applied to all types of black holes?
Yes, the Form of Kruskal-Szekeres Completion can be applied to all types of black holes, as long as they are spherically symmetric.
What are some potential implications of the Form of Kruskal-Szekeres Completion in astrophysics?
The Form of Kruskal-Szekeres Completion has helped scientists better understand the behavior of black holes, such as the possibility of traversable wormholes and the information paradox. It also has implications for the study of gravitational waves and their sources.
