Form of particular solution for y''-2y'+y=(e^2)/x
In summary, the conversation discusses finding the general solution for a differential equation with the equation y''-2y'+y=ex/x. The first step is to solve the homogeneous equation, which results in two solutions: y1=c1ex and y2=c2xex. The next step is to find the particular solution using variation of parameters, as the right side of the equation is (ex)/x. The conversation also includes a link to additional resources for solving similar problems.
filter54321
39
Find the general solution for:
y''-2y'+y=ex/x
NONE - not an initial value problem
Solve the homogeneous first:
r2-2r+1=0
r=1 as a double root
So:
y1=c1ex
y2=c2xex
...but what in God's name is the form for the particular Y (based on the right side of the equation?). I suppose it's the "hard part" of this exercise but I've tried a couple and still don't see it.
Do you type that right and really mean the right side is
[tex]\frac {e^2} x[/tex]
If so, the method would be variation of parameters.
Right side corrected, should be y''-2y'+y=(ex)/x
FAQ: Form of particular solution for y''-2y'+y=(e^2)/x
What is the form of particular solution for y''-2y'+y=(e^2)/x?
The particular solution for this differential equation is of the form yp = A(x)e^(2x)/x where A(x) is a polynomial of degree 2.
How do you determine the value of A(x) for the particular solution?
The value of A(x) can be determined by substituting the particular solution into the original differential equation and solving for A(x).
Can the form of the particular solution be different for different values of e and x?
Yes, the form of the particular solution can vary based on the values of e and x. However, the general form will still be A(x)e^(2x)/x.
Is the particular solution the only solution to the differential equation?
No, the particular solution is just one solution to the differential equation. There may be other solutions that satisfy the equation as well.
How does the form of the particular solution change if the right-hand side of the equation is different?
The form of the particular solution may change depending on the right-hand side of the equation. However, it will still follow the general form of A(x)e^(2x)/x, where A(x) may be different depending on the specific right-hand side.
