Form of the displacement, y(x,t), for the normal modes of a string
In summary, the displacement of a tight string of length L satisfies the conditions y(0, t) = \frac{\delta y}{\delta x}(L,t) = 0 and has a wave velocity v. A normal mode is a specific form of displacement, y(x; t), for the string with a corresponding frequency that is a function of the wavenumber. The string is fixed at one end and the massless ring at the other end is free to move up and down a frictionless pole parallel to the y-direction, resulting in the boundary condition \frac{\delta y}{\delta x}(L,t) = 0. To find the values of k that satisfy this condition, differentiate the displacement function y(x
RyanTG
The displacement, y(x; t), of a tight string of length, L, satisfies the conditions
y(0, t) = [itex]\frac{\delta y}{\delta x}[/itex](L,t) = 0
The wave velocity in the string is v.
a) Explain what is meant by a normal mode. Give the form of the displacement, y(x; t),
for the normal modes of the string and give their frequencies as a function of their
wavenumbers
I thought the solution was simply: y(x,t) = Asin(kx)e(-iωnt), where k = [itex]\frac{\pin}{L}[/itex] and ωn=vk. (Subbing the value for k in as well).
But from the mark scheme and looking at later questions, it's obvious that the string is fixed at one point but not at the other. My answer, I think, assumes fixed ends. How can you tell the string is only fixed at one end when the question hasn't wrote in words that is what is going on?
In the mark scheme it has k = [itex]\frac{(2n-1)pi}{2L}[/itex]. Which, when substituted into sin(kx) and then simplified, results in: sin[x([itex]\frac{\pi n}{L}[/itex]-[itex]\frac{\pi}{2L}[/itex])].
I'm not really sure how to get to the answer they have given. A hint in the right direction would be great, I know there is probably just a gap in my knowledge on this subject.
Edit: Apparently, [itex]\frac{\delta y}{\delta x}[/itex](L,t) = 0, is the boundary condition which describes the string with a massless ring free to move up and down a frictionless pole parallel to the y-direction at one end. Why is this the case?
A massless ring must have zero net force acting on it. The horizontal component of the tension along the string is countered by the contact force with the pole at the end of the string but there is nothing to counter the vertical component of the tension since the ring is free to move up and down without friction. That means there is to vertical component of the tension at the end of the string, the tension is horizontal at the end of the string, and therefore the string itself is horizontal at its very end. That means the derivative of the wavefunction is zero there - as stated in the problem.
The string is fixed at the origin so sin(kx) is correct. To find k set x=L in the expression for the derivative which will be zero at x=L. use that fact to find the condition that must be satisfied by k. Than find all values of k that satisfy that condition.
So I have to differentiate (x,L) = Asin(kL)e(-ivknt)? It seems quite a bit of work for a question like this...
The function you'll differentiate is y(x,t) = A sin(kx) eiωt. You only set x = L after the differentiation. It is easy. Since the exponential does not depend on x, it plays as a constant
Sorry for being so incompetent...
Is this correct?
kAcos(kL)=0
Disregarding the exponential part since it is a constant. What do I do from here to get the answer in my mark scheme?
Using the above I just end up with kL = 1, k = 1/L, surely? Or L = 1/k.
I haven't done a question like this before and I can't find any resources that help, I'm sorry for literally not having a clue what to do.
Related to Form of the displacement, y(x,t), for the normal modes of a string
1. What is the equation for the normal modes of a string?
The equation for the normal modes of a string is y(x,t) = A*sin(n*pi*x/L)*cos(n*pi*c*t/L), where A is the amplitude, n is the mode number, pi is a mathematical constant, x is the position along the string, L is the length of the string, and c is the speed of the wave.
2. How do you determine the displacement of a string at a specific point and time?
To determine the displacement at a specific point and time, you would plug in the values of x and t into the equation y(x,t) = A*sin(n*pi*x/L)*cos(n*pi*c*t/L). This will give you the specific value for the displacement at that point and time.
3. What is the significance of the amplitude in the normal modes of a string?
The amplitude represents the maximum displacement of the string from its equilibrium position. It determines the intensity or strength of the wave and can affect the energy and frequency of the wave.
4. How does the length of the string affect the normal modes?
The length of the string, L, is a key factor in determining the normal modes. The equation for the normal modes includes L, and different lengths of the string will result in different modes and frequencies of the wave.
5. Can the normal modes of a string be used to create music?
Yes, the normal modes of a string can be used to create music. By plucking or striking a string, you are essentially exciting the normal modes and creating different frequencies and tones. This is the basis for string instruments such as guitars, violins, and pianos.
