LucasGB
- 181
Is there a way to express the right-hand rule mathematically, without making references to... well, hands?
Landau said:Which right-hand rule exactly are you referring to? That rule concerning cross products?
UgOOgU said:I think that the right-hand rule is a consequence of the definition of the coordinate system. The three-dimensional euclidian vector space that is usually used in physics is by definition a "right-handed coordinate system". In other words, the versor products of the base 'i x j = k' , 'j x k = i' and 'k x i = j' are defined in this manner. In similar, the versor products in a left-handed coordinate system are defined: 'i x j = -k' , 'j x k = -i' and 'k x i = -j'.
LucasGB said:Apparently, every definition makes use of hands. I wonder if it's possible to define it without referring to that.
LucasGB said:Yes, but how is the "right-handed coordinate system" defined without reference to hands?
As I said, not using the concept of oerientation. See wofsy's post.LucasGB said:Apparently, every definition makes use of hands. I wonder if it's possible to define it without referring to that.
The right-hand rule is a mathematical concept used to determine the direction of a vector in a three-dimensional coordinate system. It is commonly used in physics and engineering to understand the direction of forces and magnetic fields.
To use the right-hand rule, extend your right hand with your fingers pointing in the direction of the first vector. Then, rotate your hand so that your fingers curl towards the second vector. Your thumb will then point in the direction of the resulting vector.
The purpose of the right-hand rule is to provide a consistent method for determining the direction of a vector in a three-dimensional space. It helps to visualize and understand complex physical phenomena, such as electromagnetic fields, forces, and motion.
Yes, there are variations of the right-hand rule, such as the right-hand grip rule and the right-hand screw rule. These variations are used in different fields of science to determine the direction of forces, magnetic fields, and rotational motion.
The right-hand rule is used in various real-life applications, such as determining the direction of current flow in a wire, predicting the direction of torque in a rotating object, and understanding the behavior of magnetic fields around a wire or magnet.
