MHB Forming groups as nearly equal in sums as possible
  • Thread starter Thread starter treesloth
    Groups Sums
The discussion revolves around the challenge of dividing a list of numbers into groups with nearly equal sums. This problem is identified as a subset sum or partitioning issue. Solutions can be approached using the R programming language, specifically through the subsetsum function in the adagio library. The user seeks both certainty in achieving equal sums and methods for iteratively improving groupings. Overall, the conversation highlights the complexity of achieving optimal group sums in numerical partitioning.
treesloth
Hello. I'm not sure what type of problem this is that I'm trying to solve. Any pointers would be greatly appreciated.
Suppose you have a list of numbers and you want to form them into, say, 4 groups such that the sum of each group is, as nearly as possible, equal to the sums of each of the other groups; basically, making groups with equal sums without regard to the number of elements in each. Is there a way to do that with certainty that the groups are as close as possible given the elements available? If not, is there a way to iteratively approach an optimal grouping? I'm just using a made-up dataset in R generated via:
Code:
x <- as.integer(runif(100, 250, 500))
Thanks in advance.
After some more research, this is a subset sum problem, or, in some cases, partitioning. It can be addressed using iterations of the R subsetsum function in the adagio library.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
Hello, I'm joining this forum to ask two questions which have nagged me for some time. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. But this one involves probability, known as the Monty Hall Problem. Please see any number of YouTube videos on this for an explanation, I'll leave it to them to explain it. I question the predicate of all those who answer this...
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
